Well we've got 4 months till we should find out.
I'm pegging it near Lynnfield IPC.
It wants to be a bit higher than that or its, Fail!
I somewhat disagree, while I'd like it to be higher, I can't see it.
An 8 core high clocking CPU Lynnfield IPC will still be a very good CPU.
If it was any higher (Just slightly slower than Sandy) but 8 cores, you'd be pretty much guaranteed that'd it be a ridiculous price, as it's pretty much going toe to toe with a 3930K.
We'll have to wait and see anyways.
Needing to run insane clocks out of the box to get "some" single threaded performance out of it is a big problem factor with temps and power consumption.
Lynnfield is still a country mile behind Hswell, it will have to run at silly clocks again to keep up.
Good! Most of AMD's CPU delay problems over the past 10 years can be traced back to Global Foundries issues and delays, i have been saying for years they need to dump them.It seems Kaveri will be made at TSMC:
http://translate.google.com/translate?hl=en&sl=auto&tl=en&u=http://www.expreview.com/29187.html
But Kaveri is still delayed if it comes out in 2014![]()
Are we allowed to make jokes about it being the same as AM3+ now?
As you can get a few select FM2+ boards![]()
I've got some decent hopes for FM2+ to be honest, it all depends just how much they can get out of that IGP.
I'm more interested in CPU IPC, having said that if AMD can find a way to make hybrid CF work and work well for any GCN GPU the iGPU could offer a nice boost to discrete GPU's.
With the lack of L3 cache, I don't expect Kaveri to blow me away, so if it's at lynnfield IPC without the L3 cache colour me impressed.
Just don't go a bit over zealous like you did with the initial Trinity preview stuff![]()
I'm not interested in any CPU that cannot match my i7 Bloomfied per core per clock for £150 at most.
Its serving me pretty well, i see no reason to swap it out for another unless i can do it brand new for that price.
Firstly Global Foundries...
