ahhh , fair point. didnt think of that
so you if you are on 32bit windows with 4gb, you need more ram AND new windows
Seems someone fixed the RAM issue so you can avoid the 6GB RAM needed http://cs.rin.ru/forum/viewtopic.php?f=10&t=63504&start=330
Thought might be few out there which this would help
You didn't buy premium, the bf4 marketing guys made a mess and it just means you get china rising.
No, if you don't already know, you can use your existing license from 32bit to 64 bit, just make sure you download the correct version of 64 bit windows that matches your 32 bit, ie: 32 bit Windows 7 Home premium------> 64 bit Windows 7 Home premium.ahhh , fair point. didnt think of that
Depends on what you actually bought some versions can do that some can't
Playing about an hour now on a VPN. Local bot match. Strange framerate issues. Interesting to see if its just me. I can spin round in circles with 91 FPS but then move forward and the FPS drops and stutters. Prolly just me.
Do you think this RAM fix will be safe to use on a legit copy/account?
So it's true you can't load the game without having 6GB?
You only need to use the exe in the zip for a legit copy.
