Probably just the 850W version of the PSU you bought.![]()
You can always return the 750W and buy the 850W.. 14 days satisfaction garentee and all that.![]()
But have to send back at my own cost right?
This is all your fault!
What are the symptoms if the PSU is not powerful enough?
280X Xfire vs a single 7950.. Double to 2.5x FPS i'd say..
Scaling on Xfire is pretty good on the new drivers, so performance (in some things) are almost 100%.
)E: Ds - another question, my 850W PSU came with module cables.
1. One cable is a single piece that has an 8 pin (that goes into the PSU) and the other end is also an 8 pin that says CPU on it. But the PSU already has the big chunky 24pin mobo connector and the secondary 8 pin (which also splits into a 4 or 6 pin I think)? So what is this single piece of cable that is 8pin to 8pin?
2. There were 2 cables for the graphics card, but not a third one, (thinking about a third GFX card for crossfire), how do I go about getting one?
). The other cable you talk about is a 6+2 pin (8 pin) PCI-E cable. Nice nice nice, thats what I like to hear.
So hopefully if I go Eyefinity, performance should be similar to what Im gaming at on a single monitor?
(Asked some Qs above Ds btw)
1) Are the cables labelled atall, The 8pin you're talking about will be the EPS connector. This provides some powerto the motherboard CPU socket. The connector is located top left (looking at the board) of the CPU socket.
The 24pin is another motherboard power connector (should be very easy to work out where that goes). The other cable you talk about is a 6+2 pin (8 pin) PCI-E cable.
Your cards take a 6 pin and a 8 power connector each..
2). You'll need 3 x 6 pin PCI-E cables and 3 x 8 pin PCI-E cables, six cables in all..
I'd say so..![]()
