New battery hasn't fixed the issueThe only other issue with the car is the Oil Level Sensor has gone kaput, could that have caused something else like a fuse to go?
You got a bluetooth obd2 reader to check for fault codes or access to one?
Well, I am no longer a BMW owner lol, that didnt last long..
Trader take it back?
[TW]Fox;25255744 said:A shame really, you wont find a perfect 528i Touring for a grand and the problems you described with were very minor in the grand scheme of things. Any other you find could have any number of other things wrong, too.
Very minor yes, but given the oil through the vents, the abs/tc randomly cutting out and the brakes being warped I decided that it would cost more to put right than the car was worth.
I'd have another one tbh, it was silky smooth and a comfy quiet car, body was a bit scabby but I really dont care about that sort of thing, its a grand car, problem with this one was its not really safe and given my missus was the second driver on it if the abs/tc spat its dummy out and she had the kids in the car, shes not been driving long and has never driven rwd and no abs...
One thing you can try before you get the starter done is to ensure that the battery & block both have good earths - free to do and a chugging starter is often attributed to dodgy earths.
