- 11 Dec 2002
- Darkest Norfolk
hrm, i really need to give mine a good clean out - i'm far to lazy about it generally but it does make such a difference!
Working around the corner from Monmouth Coffee this week in Borough Market and currently sipping on a filter coffee. Absolutely fantastic. Their pastries and cakes look great too and are good value besides the likes of Starbucks.
- worth paying the Notes coffee cart a visit sometime as well, undercover by the cathedral, right near the steps upto Borough Highstreet.
Just received my La Marzocco precision 17g basket and 58.35mm heft tamper from MadeByKnock.com
Damn. The basket is lovely thing, but the tamper is even better.
Not cheap, but certainly seems worth it at the moment. It seems a lot more picky about distribution and grind, but it's producing some pretty good shots. Espresso machine is getting some use today.
Anyway, PID kit should arrive later this week. Will be documenting the build on that one if anyone's interested.
What machine do you have again? Hearing about a PID build would be really interesting anyhow![]()
Awesome. I thought you might be PIDing another machine but if you happen to have the same machine as me then it's even more interesting. I'd quite like to go that route 'some day' myself.
Sounds like a strange issue with the Silvia. Have you tried warming it up? Could be a dry joint like issue (I'm totally guessing here).
The Auber PID kit is around $200 plus postage and probably customs charges...
DIY PID kit - ~£50 and some research.
Version I think I'm going to do is going to tie into the steam function as well. Apparently only requires an additional solid state relay.
I currently investigating if I can add a shot timer that starts counting up when you hit the brew button. Not looking easy at the moment. I just want a timer that runs of 240v so I can tap that into the mains feed as well. But have a 240v trigger so I can tap into the brew button. Not looking possible from the timer's I've seen so far.![]()
Sometimes it won't happen and it'll stay on for hours. Other times it'll happen almost immediately.
What I'll end up doing is completely removing it from the casing and setting it up on a insulated test bench and run it out of the case and check everything. That may have to wait now as my parents have just stuffed my christmas present idea for them *they've gone and bought a bean2cup machine - they were going to get the Silvia and the MC5 for Chrimbo* so I've now got an MC5 to locate in the kitchen somewhere. That'll make the other half happy....![]()
Well I've had my new Gaggia Classic for just over 24hrs so far! I was previously using my housemates cheapish £80 something Delonghi machine and this new one seems to make the coffee stronger with the same amount of grounds which seems odd![]()
It was a big upgrade for me from the Viva I used to use (and then, briefly, a mocha pot /gag). What grounds are you using? You should probably try to get a decent grinder to get the most from your machine. You may also want to look into the pressure mod (easy to do and someone on here can provide you with the bits you need for free as long as you are willing to then send them on to someone else needing them afterwards) and at the same time purchasing a new basket. All of these will improve your coffee to no end
I really want to hear how this goes and also all the places you get your parts from. I won't completely copy what you do verbatim, honest (note: this is a lie)![]()
I'd quite like to have something to set a timer for a shot from the other way round - e.g. set it for 22, 23, 25, etc seconds and the machine is only on for that amount of time. Then I can adjust my grind and tamp to produce the correct amount of espresso in this time.
Ah, the joy of having been single for almost a year is that I'm starting to fill up my place with tons of shiny gadgets![]()
I didn't use it that often as it's just me that drinks coffee now, but still.....
Good work on the Gaggia ClassicIt was a big upgrade for me from the Viva I used to use (and then, briefly, a mocha pot /gag). What grounds are you using? You should probably try to get a decent grinder to get the most from your machine. You may also want to look into the pressure mod (easy to do and someone on here can provide you with the bits you need for free as long as you are willing to then send them on to someone else needing them afterwards) and at the same time purchasing a new basket. All of these will improve your coffee to no end
Just random pre-ground espresso stuff from Tesco for the mo. Got some random brand I can't remember and some Lavazza stuff too. Still getting used to this new machine but I might look to upgrade bits when I get bored
The basket that came with this machine was the newer style with the plastic bit under it. According to the leaflets that's a newer style but then again newer is a relative term when they've been selling the same machine for years
Feels like this basket holds less than the previous cheap Delonghi thing and yet everything tastes stronger! Not sure if that's normal lol
)Just seen that there is one a couple of minutes from my office at Bond Street. I usually visit Taylor St Baristas but I may have to pop there tomorrow to check it out.just popped by workshop coffee this afternoon and wow, very impressed with cult of done, really nice, sweet, rich coffee with a crazy aromas of Jasmine washing through. Lovely & highly recommended (and always good when the till jockey starts talking about when the coffee was roasted and when its going to be at its best)
So your pre-ground stuff from a store will basically be ground too coarsely, meaning your the shot will go through too quickly (I'm guessing to make your shots it's taking less than 23-26 seconds from when you hit the 'go' button?). This usually means that you'll get off flavours - often sour tasting, sometimes overly bitter, sometimes just generally watery. With better ground coffee you'll get a more reliable (and much nicer!) end result.
