Checked the site mate, doesn't appear to list them yet. Having to search manny codes.
Or how about you suck it up and buy a 7990 which bitchslaps this and the 290![]()
Coil whine, high power usage, 90c heat even with 3 fan cooler, noisy, some games still have issues with CF/SLI.
No thanks Jeff.
No thanks Jeff.
Are there any BF4 benchmarks using the 780ti anywhere ?
All this does is point out how great value the 290 Pro is in all honesty, its only slightly slower than a 290X, which in turn isnt that far off a 780Ti. And the 290 Pro is almost half the price..
Something tells me the winners here will be people who buy 290 Pros when it comes to power per pound spent, factor in the Non Ref cooler versions that will come out, NeverSettle Bundle being added and then Mantle in the future, im still not convinced Nvidias showing is better.... thats my 2cp
No coil whine on mine, high power usage, its dual gpu what do you expect, that's a given with any dual card. Loads at around 85c for me, as for game issues with crossfire ive yet to encounter any as of late.![]()
A 7990 user with zero coil whine? You're a very lucky chap then.
NO!
OcUK has stock of Gigabyte and MSI, you can collect from our shop now or have delivered for tomorrow, you should check our website before making a sweeping statement which is incorrect.![]()
Not really, there's quite a few that aren't having the issue, just seems random. Theres a few gigabyte 7990 users on here that don't have it either.
