Has anyone seen this disco in BF4 ...
http://www.hotukdeals.com/deals/bat...dlc-now-28-99-simplycdkeys-1704654?p=19604451
Glad someone else has noticed this. I know im getting on a bit but thought surely my eyesight isnt that bad yet.Might try 80 fov but totally agree with above. People are smaller...
Is any one having problems playing against high ping players? Just been on a server and about 6+ players on the opposite side were 200+ ping. It was pot luck if you hit them or not?
Bigger the fov the less fps.
I get this but worse sometimes.Using old drivers, mine did exactly that, their own fault![]()
Dropped fov to 75, makes things so much better.
1920x1200 here, (yep theres still a few of us left).90 is about right for 1080p. Tried 120 lol and had a sort of fisheye lens effect, too little (70) and I get tunnle vision effect
Whats your system spec? A few users have reported gradually increasing memory usage the longer they play, also increased cpu usage. Theres supposed to be a memory leak issue.At release I had no probs running it on ultra, but after a session yesterday was getting much lower fps and had to drop to high. Any ideas why this might be?
Im also finding ADS more responsive now. First round with lower fov i managed a 5 kill streak, few at close range but a few more at longer ranges. Targets did appear that much larger. Saw a vid on yt, think it was by rivalxfactor who reccomended a lower fov for bf4 than what you would have used in 3.Hmm fov 75 makes finding targets in undergrowth muuuuuch easier not exactly suprising but in most games I can manage the same with 90 but not in BF4 for some reason, good call on turning that down especially as its more fluid in transition with ADS.
