Cheers Gibbo.... order going in now!.... and the EVGA 780ti SC too![]()
That's not fair Gibbo!i can find the 970D cheaper elsewhere but i don't see you reducing that price!
Still would have been nice to mention these things.![]()
Your friends over at caseking
http://www.caseking.de/shop/catalog...B970D-6858-cm-27-Zoll-DP-HDMI-DVI::20681.html
Not much but it makes a difference when i take my other items and P+P in to consideration![]()
Well I'm glad you found your cable, but it is not my job to mention these things. I find it amusing how you think it is though!
It arrived as promised.
Power Cable in the bottom of the box - thanks for that tip!
Used the supplied Dual DVI cable with my HD7970 - straight in at 1440.
No dead pixels. Lovely colour, had to reduce brightness a bit.
I'm really happy with this monitor!
However, the warranty info. all appears to be Eastern European and the Samsung UK Website does not recognise this model number, so won't allow me to register it (my Samsung TVs and camera are registered there to get rapid support).
The Samsung US Website does recognise it, but since I don't have a US address, I cannot register it there either.
I've Webmailed Samsung UK to ask about registration, so its now "wait and see".
I registered my 970D OK on the UK site so perhaps they forgot to add the 971D.However, the warranty info. all appears to be Eastern European and the Samsung UK Website does not recognise this model number, so won't allow me to register it (my Samsung TVs and camera are registered there to get rapid support).
Ah yes, the pricing works out more or less identical.
Caseking is not a competitor, so link can stay as were part of the same company.![]()
Its not the question of being amusing, if l was one of the first in this thread, l would have mentioned where the power lead was found and confirmed what cable's you get.
Why should l have read the 970D thread when mine's 971D, there could have been a change in spec's not just a matte finish.
This is why you join a forum, mentioning little things like that it just save's a lot of hassle for other members who buy this monitor.
