Well I'm in the same boat - I'm trying to decide between a 7990 or a 290 pro (or maybe 2
). However, I am more sensibly moving from a 6990
Looking at the benchmarks the 7990 should just about double my frame rates which is my rule of thumb for upgrading.
So why the hesitation ? I run triple screens at 5760x1080 eyefinity and crossfire (via 6990). It has not been smooth sailing at triple screen resolution - I still suffer micro stutter on quite a few games. As we know frame pacing is now implemented up to 2560x1440 but not yet higher or for eyefinity. I am tempted by the built in frame pacing at higher resolutions on the 290 pro but it is soundly beaten by the 7990 in terms of raw framerates. AMD are promising the frame pacing drivers at higher resolutions but I have a nagging doubt that they will abandon that on 7xxx series and below and say those that need crossfire and triple screen should be getting 290 series where it is built in. Awaiting a crossfire eyefinity test with 290's - anybody seen any reviews ?
At your resolution the frame pacing issue is supposedly addressed as you have no doubt experienced but it simply will not be a noticeable frame rate improvement for you - unless you try tri-fire with 7990 and one 7950 that should give a nice boost.
I may wait and if frame pacing driver is released for eyefinity resolution I will try to pick up a 7990 then .... if there are any left.
