Not that I'm aware of, even if you could you'd still probably get a better deal just going somewhere else.Thats probably what I'm gona do. When a service provider offer you an *upgrade* can you also get deals on sim only?
Also with google hangouts. If I sign in on a new device, will it download all my sms on to the new handset?
Also does anyone else not see the N5 show up when you try to install an app from the playstore through your web browser using say a PC.
No. SMS Backup & Restore is your friend.Also with google hangouts. If I sign in on a new device, will it download all my sms on to the new handset?
Only issue is the way attachments are done, i mean they don't save anywhere :/
Also: built in battery % support: http://www.androidpolice.com/2013/1...deal-but-heres-how-to-enable-it-without-root/
why do people want to see their battery go from 56% to 55%?
Stupid question but how do I check that the GPS is turned on?? Will need to us TomTom satnav and I thought it would be under settings.
It wasn't a rant, I was intrigued.
Thanks for your in-depth answer.
Has anyone seen very high Android OS Keep awake battery use?
On my girlfriends phone this process is using 50% of the battery and around 5 hours keep awake time over the day which seems very odd......
I have tried to install wake lock detector but its not compatible with 4.4 OS....do you think its an app she has got that's got an issue with 4.4 or something else?
Thanks
why do people want to see their battery go from 56% to 55%? Surely all you need to know is when to charge it?
Just charge it nightly![]()
Thinking of selling my ip5 and going for this.
Anyone done the same? Or with a galaxy?
Or would you say so OMG WTF STOOPID if I were to ditch apple.
Find the BetterBatteryStats thread on XDA the developer has posted a Beta version that works fine on 4.4
