 - 20 Apr 2004
 - Rugby
match make dont work, most my fav's show as offline/with a ping of "-" i also have a ping "-" which has got me kicked a couple of time, quite a bloody mess
			go ingame, open console type game and it'll appear like game.timemaxvariable or whatever it's called, and set it to 120, if that doesn't work i'd try completely wiping origin and bf4 from drive and even deleting pre-set folder that are left after you re-install.Urg, struggling getting any more than 60 fps, even tho i'm running it at 1920x1080 @ low reso and im still not getting any more than 58-60 fps, odd as this has only started occuring since I setup the cfg file, have deleted it and it wont go above those fps. Prior to this i was getting 80-100 depending in high @ 2560x1440..Any ideas?
sys:
i7 950
titan
I suck at the SRAW. Can hit stationary targets, but how the hell ppl hit moving choppers I do not know!
, at the end you see them just pointing at empty space then it's "...killed 100"
yeah i've watched videos and cannot for the life of me figure out how its done, at the end you see them just pointing at empty space then it's "...killed 100"
Exactly... I wonder if we only see the 1% of shots that hit![]()
, it's the same for me with tv missles though can't hit sod all, i know my aim is rubbish, but it doesn't help i can't settle on a decent mouse sensitivity on vehicles so i can get a decent turn going on the turrets
.I've had 2 x BSOD and 1 x Freeze tonight... Brilliant night.
it's the same for me with tv missles though can't hit sod all, i know my aim is rubbish, but it doesn't help i can't settle on a decent mouse sensitivity on vehicles so i can get a decent turn going on the turrets![]()
) and I thought the same at first, impossible to control but once you get use to the sensitivity (don't keep messing with your sensitivity, just messes your aim up as you don't have time to adjust etc. besides I don't think vehicle sensitivity affects TV missile sensitivity??? IIRC mine is set to about 30%), they are extremely easy to use. As always, practice makes perfect!Ahh bfbc 2 good times....
........prediction........ if ur good with tv missile sraw really isn't that hard to use..
....... once you get use to the sensitivity (don't keep messing with your sensitivity, just messes your aim up as you don't have time to adjust etc. besides I don't think vehicle sensitivity affects TV missile sensitivity??? IIRC mine is set to about 30%)
Once I finish a few games I have got here and if BF 4 still isn't fixed..... going to reinstall it, the thought of ghille suit + c4 + VSS + AT4 + amazing rush maps =![]()
First BSOD's since the game started? Trying to get a gauge on my BSOD earlier that according to people here is one usually found with voltage issues, yet I've also heard graphics hardware, RAM, drivers, and Windows wasn't sure so it decided to use this error code.
I've tried my best to force another BSOD with various software; memtest86, x264 encoding benchmarks and it passes everything fine.![]()
just wow.
choppy game, still crahing randomly, netcode even worse and i can find any gun I actually enjoy besides m16a4..
This game
dunno then might just be me, i've never used the jets/helis etc cos i'm crap with them and its just a waste of a decent vehicle, so not seen tv's before, when i've tried they just seem very skittish, so i figured it was sensitivity ?
never really played bfbc 2 that much (in comparison to bf2/2142/3) but tempted to reinstall with all the comments.........
Leading target and prediction, if ur good with tv missile sraw really isn't that hard to use..
