Sorry bud, you've got a heck of a lot more reading and Youtube watching to go before you knock me off my perch
Before hailing the Vision Spinner VV Ego as the budget vaping nirvana - at least understand the difference between VV & VW... 1.8 ohm coils should never need to taste burned - in fact, I've got a 1.3ohm, dual coiled Igo-W dripper sat on my Fasttech.com 1100mah EGO-T and it is a little pocket - rocket.
I have the new Aspire BDC Glassomizer making it's way to me from www.celticvapes.co.uk (Kernow Vaping) from the most Excellent Gary Thomas - hailed as the poor (or tight: my strictly prohibited vaping budget is entirely self-imposed and not at anything at all to do with my wife having my testicles on her key chain!) mans' Kayfun Lite...
Before you can say something is excellent, you need to be able to compare it to higher end gear to make that assessment fairly. I'm fortunate enough to have a bachelor best mate with zero laserbeam stares at the back of his head in order to curb his spending, so I get the opportunity to try out the latest high end kit, without needing a 2nd mortgage...
I shall post up my thoughts on the Aspire, with my usual blunt honesty, once I've had a good going over it
As for cheap samples, Smoke Rainbow is ok if you're after mass produced (Hangsen, Liqua, Dekang etc) and the odd cheaply made flavour base in 1ml samples for 50p, but it's not such good value compared to £1.49 for 10ml tasters of custom mixed, with a higher choice of VG
G ratios and Nicotine content, plus 90p p&p (when buying just 10ml tasters) or 60ml for £7.25 from Www.joosejuice.co.uk
Or really take a chance of saving money and try www.yaeliq.com = 100ml for $18 (free DHL if you spend over $50)
Or complete control of what goes into your juice at https://8bitvape.co.uk/?p=home
