As others have noted you really should be careful with those vidmem vrm's as well as vram chips (some low profile aluminum or copper heatsinks can do the job). even with ref blower in the uber mode their temp creep up quite a bit.
It looks like you'r rocking Antec 300 with the 120 fan cut out on the sidepanel, so some good high airflow fans (AF120/Spectre Pro or GT's) would help a lot too.
		 . Not uncommon on 290's from what I've read. Hopefully AMD fix that issue soon.
		 But also very effective!
