Am I confusing myself. Is the KitKat update coming to the 1st generation Nexus 7? Or is it only for the 2nd generation one and I've got my hopes up for nothing?
has anyone who is stock but rooted with a custom recovery updated to 4.4. If so, how did you do it and did it wipe your data?
I want to get from 4.3 with TWRP and ROOT to 4.4 with TWRP adn root ideallywithout wiping data !!!
The funny volume adjust behavior is probably down to the way 4.4 does bluetooth volume, it's no longer adjustable by both the bluetooth device and by going into volumes on the phone/tablet it's all controlled from the bluetooth end now.Hey,
I did a factory reset and flashed the factory image for 4.4 - all nice and smooth, but now Bluetooth audio is messed up.
Lot of skipping and audio distortion, and the volume adjust is weirdly not linear any more?! Like I press up a few notches, and it will go up, up, down, down, down, up, or something.
Totally weird! Anyone else having similar problems?
Cheers,
Su
[edit] Just remembered that my RAZR HD on 4.1.2 does the exact same thing with the volume, and I was never able to find a solution
[edit2] I've had the KRT16S update pushed to my device - no change.
Hey,
Cheers,
Su
Just cleared framework and 4.4 OTA came up as available.
A few people in the UK also reporting success on XDA.
