** VTX3D R9 290 PRE-FLASHED TO R9 290X & VOLTAGE UNLOCKED!! **
Blessing in disguise, no impulse buying! :p:p
Have to agree in a way. I sort of bought it on an impulse :D
Let's let's look at it this way...for example the MSI 290 at £330...pretend the BF4 and silver ticket worth £30, so the card itself worth £300. So paying for this unlocked card at £360 is essentially paying 20% extra for average of 3-5% gain doesn't seen very good bang for bucks, but in a way it's not much worse than going for the 280x/7970 instead of the 7950 back then £180 vs £240...it was also £60 extra, but in that context, people were paying 33% extra for 3-5% gain :D
Most sensible thing I have read today.
Edit: what I meant was you can get a nice 290 for £300 assuming you sell the games, and the 3-5% gain will be hardly noticeable.
Ultimately I think this is what stopped me.
Although I now have "non-buyers remorse" :)
If I get a regular 290 now, hidden in the fan noise, I'll hear a voice whisper "could've been better, could've been better"...
Rather than this being an expensive 290 I see it as a cheap 290X. You get a 290X GPU rather than a binned 290 part which may not have made the grade.
Sure 3-7% over a non-X at same clocks isn't much, but it feels nicer when you get it for £60 cheaper than an identical 290X. Plus GPUZ says 2816 rather than 2560, giving you an instant 10% larger nadger. Alternatively, spend less on untested 290 and take the lottery.
I would have thought there would have been the version with the tech labs cooler, not the water but the huge air cooler. Now that would have been a talking point...
Not to mention youre paying for the 2 year guarantee as well..
Actually I have had no email to confirm dispatch of mine but in my account it says its been dispatched? Ive usually received emails from OCUK
dont worry I had that last time. The email took a couple of hours to appear.
If in doubt just create a new post in Customer Services to 5UB to confirm before it gets too late. He is top notch for replying quick
I didn't get an email about dispatched also but talked with RJK and he says its been sent so I wouldn't worry if yours as moved to the Order History section.
HI there
I put the price back down, as I found another AIB we hold in stock which also flashes successfully, so we now have plenty. :D
Here are the ones which did not manage to flash, but still voltage unlocked for your convience. ;)
VTX3D Radeon R9 290 "Voltage Unlocked" X-Edition 4096MB GDDR5 PCI-Express Graphics Card @ £319.99 inc VAT
Pre-flashed by Overclockers UK Technicians using a voltage unlocked R290X BIOS unlocking voltage control upto 1.412mv.
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:-
- Radeon R9 290
- GPU: Hawaii Pro
- Stream Processors: 2560
- Core Speed: 1000MHz
- Memory Speed: 5000Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- Cooling: 2-Slot Blower Fan
- PCI-Express X16 lane required
- 750W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warraanty: 2yr
Features:-
- 1000MHz Core Speed
- Unlocked Voltage
- DirectX 11.2 Support
- Open GL 4.2 Support
- Dolby TrueHD and DTS-HD Master Audio support
- Crossfire Support upto 4-way: Native software crossfire (No bridge required)
- Gaming @ 4k Resolutions (UltraHD)
- Synergy with next-gen game consoles (Mantle)
- Graphics Core Next (GCN) architecture - optimized from previous generation products
Only £319.99 inc VAT.
ORDER NOW
Your listing states "2560 Stream Processors" if its flashed should that not be 2816?
There are two, check them both. ;)
One is flashed, but the shaders did not unlock, hence only voltage unlocked and only £319.99
The other the cores did unlock and is hence priced at £359.99
