New drivers and ASUS bios flash and then 'updated via Asus OC thing' given more stability.
Gaming clocks, what a monster.
Not sure if I am lucky, but I am getting 1150/1500 stable with no artifacts on stock volts.
Looks like you won the silicon lottery.
I hate to think what they will use @1200/1625.![]()
Hi,
Is it normal to have audible coil whine after putting a waterblock on a 290?
Im not even sure it was making that whine prior to placing the waterblock as I couldnt hear anything over the stock fan.
Not sure what to do really, maybe reseat the GPU and try again?
You prob couldnt hear the whine over the fan. But when its quiet then you hear it. Same happened here
Yew my 290x whines. Not bad as my older 7990 tho. I can ignore this
Yay! 1.3v hit nicely on 1285/1625
May flash bios and go some more
Edit: but since moved from Windows 7 to 8.1 my CPU doesn't seem to score as high In benching now :-/
Will it go away? is there any way to stop it or should I just RMA and hope the next card wont make the same noise (and is that a lottery regardless)?
That's under water right right ??? Nice overclock man![]()
Hey, I was wondering if there a way to increase the voltage for the memory?
Currently using the unlocked VTX 290x...will get black screen problem/crash when clocking the memory too high.
I tried putting that on max on MSI Afterburner, it doesn't help much comparing to +0 to me. Would still black screen going beyond 1550MHz.I've found adjusting the AUX voltage helps when overclocking the memory Marine, as for dedicated memory voltage control, AFAIK, there's isn't, not yet at least.
