Well done, great guide.
Put mine on too, along with the beast cooling the vrms.
what made you pick this cooler vs. say the MK.26 ?
So all you need to buy is these 2 products:
1. ARCTIC COOLING Xtreme III
2. Alpenföhn Passive DRAM / VRAM Chip Coolers
They will include EVERYTHING you need to do the above mod? ie. it includes all the thermal paste/ insulating strips etc..
Overall, how long did it take from start to finish?
Note D: This cooler only covers 2/3 of the chip, so I put a piece of thermal tape on the other 1/3 so it touches the mounting plate.
Using the 12V feed to the fans, they run at a constant speed regardless of load.
Slightly quieter than the stock cooler at idle and way quieter under full load. Much quieter than my HIS IcyQ 7950 Boost under full load. AX III's fans are only just audible over my fairly quiet case fans.
For those interested in the comparison to the reference cooler, here's the result of running Heaven for 45mins on 1100MHz/1500MHz/+31mV (+20mV was stable for Heaven, but not stable for Sleeping Dog's bench so I increased it to + 31mV). Settings, fanspeed details are in the post below:
Mine is unlocked to 290x, but should still be good contrast. It's good to know that the Xtreme III shaved 20C of the temp (and with the benefit being much quieter than the reference cooler at 3000rpm).So...I had a bit more play today on the VTX (unlocked) 290x, and played around with fanspeed and overclocking a bit, trying to find the best balance between voltage/temp, overclock and fanspeed, and I have settled on using 1100/1500 for now, which required a slight bump in voltage of +30mV (upped from 1250mV to 1280mV), and change the fan profile to speed up sooner at a lower temp (70C at 50%, 80C at 55%, 90C at 60%)...and here's the results of running Heaven on 1920 res, 4xAA, Extreme Tesselation for 45mins, and it never went above 55% fan speed and 81C:
My room is around 18-19C.
"He Who Dares, Dremels.."
Glad to know yours worked out great too.
