Yea is it just guess work?
well there's the unlock rangefinder that mounts onto your sniper rifle and give you a digital output of the distance from you to where your gun is pointed, so you can then use "V" to change the zeroing to match it as close as possible. or the other way if you don't have that is it use flags to help guesstimate ranges. e.g. see a guy around an objective, aim at the flag and it will give you a range to the flag...so at least you have a reasonable ball park figure
