- 25 Apr 2010
- Ipswich
I think in future if I buy "high-end" products and don't get on with them I will keep them for trades instead of selling them. Lesson learned.![]()
Hahah
done of those ages ago and even posted a pic of it and if iirc you commented on it.
IMPORTANT
It has come to my attention that vapertrain maybe selling fake AW IMR's. I'm getting confirmation from AW if the pics I sent them of the batteries I bought are genuine or not. If they are fake I shall start a Paypal dispute and ask that people avoid using them until I get confirmation.
Edit 1)
These are authorized resellers:
-UK Ecig Store
-Cloud9 Vaping
- The Photon Shop
-http://www.ecigwizard.com/accessories/bc/mod-batteries/
-http://www.flashaholics.co.uk/
Update
There has been some behind the scene drama an several email exchanges between myself and VaperTrain, despite VT admitting they don't stock fakes and buy all their stock straight from the manufacturer's and not from third party resellers, AW confirmed the batteries I have are fake.
So if they want to take liable court action that is between them and AW now.
See AW's response:
http://www.cpfmarketplace.com/mp/sh...50-IMR18490-IMR18650-IMR26500-*Part-2*/page47
I have left VT with the above link and requested a refund. Let's see what they say now, otherwise I will proceed with a PP dispute.
Out of curiosity, how can you tell if they're fakes?
Our batteries all come direct from Andrew Whan.
AW batteries have been copied for the last 3 years and the giveaway is usually the price. There is next to no profit in genuine AW, so if you see them at a silly cheap price – they are either a loss leader or a fake.
Hope that helps
Jason
@Window - Is that a custom made VTR?
Please can you tell me what is the best to buy to use as a flavour wick for the protank 2 mini? I want to buy some cotton or silica whichever is best and make my own flavour wicks.
I will post some reviews of the flavours when I have let them steep for a bit.... Seriously though I need to stop buying vaping stuff now!just received my nemesis clone finally and centre pin is meant to be telescopic and had a flat head on it but it doesn't push down AT ALL and the pin is bloody hard to attempt to undo. also none of my batteries seem to fit in it and there's a lot of wobble room, am I meant to tighten this pin down?
I would have thought so as my KFL and their dripper both have Huge clearance issues but wanted to check before I broke something as I've been waiting 6 weeks....
I also have a nemisis clone.
The centre pin is a screw, so loosen it, fit atty, tighten centre pin
Also there is a tiny screw on ring section of the tube, about 1-2mm, (beauty ring), remove it
Also u can adjust the bottom, up or down to help fit with battery.
There is also a kick ring included, dont use it unless you are using a kick![]()
