Bit OT, but this will be an interesting one.
Holes in pistons are not that common. In this case, the hole in the piston isn't really the problem (although clearly it is a massive problem!), it's more likely the end result of another issue. My money would be on a fault with ignition and/or fueling mix although there could be other possible causes.
Also worth asking as it may be relevant, but has any work been done to the car since you bought it?
