Motorsport Off Topic Thread
I've never bought the theory of "learning a new car".
If you are good. You are good. A top driver like Hamilton, Senna, Alonso, Vettel should be quick from the get-go.
Many drivers have won a WDC in their very first year with the team.
Winning in the first year doesn't mean they couldn't have done better. Ultimately I think this matters most when the car is less good. I don't think the difference is massive, but when drivers can change multiple settings for multiple corners in a race these days, it does make a difference. If you're at Mclaren and have 3 brake bias settings, and at Merc have 10, then you both have a new car that corners differently, you have different brakes, you have a different straight line speed and different tyre wear. It's going to take a few hundred, or thousand corners before you get a feel for which setting to use at which stage of a race on which type of corner.
The whole "this car was built for driver X so is almost completely impossible for driver Y to use" is rubbish. What a driver prefers and what a driver gets are different. But even if the car is exactly what you wanted, it still takes some getting used to, every driver says this, every technical guy, everyone.
I mean you have three different settings, you HAVE to do 3 laps and try the same corner with the different setting each time. This is simply fact, if someone knows the difference between those settings already, they are 3 laps up on you. Of course, first lap, cold tyres, second lap, warmer tyres, third lap, if a qualifying run, maybe the tyres are already going off. So realistically you need to do an entire run on the one setting, the do another run on the other setting and feel the difference. Then factor in how the lap feels if you change setting for every corner, then how does the car react in the wet, at high fuel, at low fuel, on softs, on hards. This can't possible be instant knowledge and can only come from time spent driving, nothing else.
0.01 here, 0.01 there, 0.001 somewhere else, every lap, for a 70 lap race. It's not massive, but it's a difference, it adds up and it takes time to get the absolute max out of a car. That 2/10ths a lap wouldn't make a difference if Vettel was new to that RBR, but would make a lot more difference to the Mclaren or Merc of this season.
He scored more than double the points of his team-mate.
Name me another driver from a leading team, who did this?
Answer: nobody.
The only person you can truly compare a driver to, is his team-mate and of all leading teams, Alonso compared the best.
Can you name me another driver who had Massa as a team mate, or had a team mate who allowed his no.1 driver to pass him so many times this season?
As for another driver who had more than double the points of his team mate..... Vettel for one?
I would say Vettel compared to Webber was a far bigger gap than Alonso to Massa, because Massa almost never had a race winning capable car, Webber absolutely did. Likewise Massa has a couple races that weren't lucky, he got hit a couple times and a tyre blow up.
I think the comparison to team mate is pointless though. Driving on at full speed with a wing stuck under your car and taking yourself completely out of the race for literally no reason at all, on the first freaking lap was one of the biggest blunders of the entire season frankly. It was beyond stupid, the outcome was a foregone conclusion, and he didn't put his race at risk once, on the straight before the pit entry but ignored the pits and went flat out down the start finish, and ended his race.
Sorry but, most brain dead move of the season for me goes to Alonso, hence me not believing he had a good year. Couple that with an attitude at more than one race like Monaco where, in a procession of a race with almost no over taking and no real ability to overtake, he had a brain fart moment and lost a place due to sheer carelessness. Throw in that he's gained quite a few points by having his team order Massa out of the way and I would hardly call it a great year for him.
EDIT:- balls, the stupid comparison website hasn't got the last two races in the numbers for some unknown retarded reason so. Vettel was 1 point shy of having double Webber's points.
I'm in two minds on Hulk.
He has outscored his team-mate heavily.
But as you stated, there werent any stand-out performances that made me think, "wow".
I remember last year when Perez made his tyres last longer than anybody else, I thought, "wow". When Vettel won 9 in a row, I thought, "wow". Hulk is liked by a lot of people, though. Many people rate him and are disappointed to see him go. Hulk did get pole in Brazil a year or 2 ago - that had the "wow" factor.
I don't dislike Hulk, but the Sauber was clearly better in the last 6-7 races. I think Gutierrez being quite so utterly terrible actually made some people think Hulk was doing way better than he was.
Hulk had a car that was just genuinely pretty fast in qualifying later in the season, got higher up the grid and used the fast straight line speed to hold people up in a few races for some pretty good finishes. I don't think as you say, any of the races were spectacular. Sauber just got together a good qualifying/high speed package and used it to their advantage.
Sauber particularly second half of the year sorted out two key things, traction and straight line speed(and both go together pretty well), made Hulk extremely hard to pass, nothing more.
I think Di Resta, with plenty of dodgy tactical qualifying decision(seemingly most by the team but some by him) coupled with not great quali speed meant that car started further down the grid but did very well in races. But for 5 or 6 dnf's in a row(I genuinely can't remember how many were his fault and how many were car/other drivers, I think 1-2 were his fault, the rest not?) he would have quite easily beat the Sauber and more on driving style and overtaking than the "get out front and hold everyone up" method.
Like they did on Perez, you mean?
And then fired him after 1 year?
When you are a front running team, you hire established drivers who can win WDC.
They lose Hamilton and they hire Perez. Then they compound this error by hiring a complete rookie.
Now, unless they believe that Magnusson will win the title in his first year, they have already conceded 2014.
Actually they will have FAR more information about Magnusson than they ever did about Perez at this time last year.
Im sure you were saying the same about LH in 2007 too
The only reason Magnusson is with McLaren is that another team was going to have him but let McLaren down.
Wonder how much it cost McLaren to put perez in force India?
I haven't posted anything F1 related in ages, boring second half to the season :p
But the off season should be quite interesting with 2014 developments over the next few months.
I'll kick off with what appears to be Ferrari's 2014 1.6 V6T F1 engine in a La Ferrari!
Complete with air scoop.
Doesn't sound too shabby either.
Why would it cost McLaren anything, the contract hadnt been physically signed for next year .....
I'm not convinced by that La Ferrari. Seems like an aweful lot of effort to mod an incredibly expensive development chassis of an as yet unreleased car to test an engine it will never use? They can test the engine pretty extensively on a dyno, and a La Ferrari chassis offers very little in terms of comparisons with an F1 chassis?
The source website for the video doesn't seem to mention an F1 V6 at all either.
But then it certainly doesn't sound like an NA V12?
Is there anything in the regulations that allows them to test engines outside of F1? I've always assumed teams were restricted to where they could test parts :confused:
Ron Dennis has a 959 911 with the TAG Porsche F1 engine in the rear. 1100bhp 911. :D
I would imagine that if that is a 2014 v6 in that La Ferrari, then it's been ok'd by the FIA. You'd hope anyway.
I'm not 100% sure on the engine testing regulations but I believe the season doesn't 'start' until either the first test or January 1st, I'm not sure.
Back when BMW were in bed with Williams there was a rumour of a BMW 3.0 V10 being put into the back of the then BMW LM car for testing which made some other teams almost explode with indignation.
Yeah they are free to test engines how they see fit. The regulations on testing apply to the chassis.
It just seems like a waste of moeny (and a La Ferrari) to go to that effort. And its not like its a mental PR stunt as the F1 engine would be 250bhp down on the V12 hybrid that should be in the La Ferrari anyway?
All seems a bit odd.
Could be that the La Ferrari was damaged/scratched/a prototype tub any number of reasons that it wouldnt be used/sold.
All speculation ofcourse.
so still waiting to see if lotus get the quantum money as well
wonder if it will go through..wouldnt like to bet on it either way
The fact that they have hired Maldonardo makes me think that it wont. Both Lotus and Quantum have been very clear that they would have preferred Hulkenburg and that lotus would have signed Hulk if the Quantum money was going to come through. Signing Loldonardo is a clear sign that the money isnt coming
i dunno, apparently the funders are from all over the place , i dont get what good it will do quantum to play this game
i think it just got to crunch time for lotus. they had to do something with no guarantees. better that than ending up with nothing.
we shall see
both monies would be nice
The problem is Quantum said they wanted Hulk, not The Idiot. I suspect Boullier and Genii put a deadline on the Quantum deal and if nothing happened by then they would make the decision themselves. I suspect they now see the Q deal as nothing concrete so did the safe thing for the team, factory and staff.
which , as annoying as it is, was the only option. still hoping for the quantum monies!
Yep, if they wanted to test the new engine, I would have thought putting it in a 2011 Ferrari F1 car would be better than a La Ferrari.
Presumably there is more space in a LaFerrari, and the gearbox and drivetrain would be more likely to cope with the extra torque, which I'm fairly sure the the 2011 model wouldn't (presuming they haven't got the 2014 gearbox ready to test as well of course).
