Why don't you just buy BF4 media? You can sell it later?
Yeah you can buy from US PSN but you can't sell it?
What you save from buying from the US store will probably offset the money you'd recoup from reselling it. If that makes sense
No buzzing from mineCan someone check for me plz?
Mine downloaded at full speed earlier, 40MbpsIs anyone's LAN connection a bit slow as well? Running the speed test, I only get about 25MB/s throughput, whereas I should be getting the full 60MB from my connection. Tested the LAN cable on my laptop and its fine.
EDIT: Could just be the PSN servers still getting hammered I suppose, but all the tests consistently seem to be 20-25MB/s.
Hi
Would I notice a difference upgrading from a 720p tv to a 1080p tv?
Hi
Its not as simple as one poster thinks....what size screen and how far away so you sit?
I am hating kill zone.
I enjoyed 2 and 3 and the vita game, but just not getting on with this one at all![]()
Plugging headphones into the pad and then having all the audio play through them is such a brilliant feature. It feels like the PS4 is this gens 360.
What shall I do regarding my buzzing PSU? Is it worth calling Sony or what?
call sony they probably will replace it next few days
Does PS4 support 3D gaming?
I thought I seen somebody comment that they played that Resogun in 3D on here![]()
It supports it yes, only Trine 2 at the moment though.
