If I was that big a fanboy I wouldn't be getting the PS4 would I?![]()
You're just getting it to use as a foot rest, admit it
How would u not expect me to let 2 broken consoles colour my judgement in the future? It's like if i had 2 LG tv's within a few years and they broke, i would most likely avoid that brand in the future seeing as i had a bad experience with them i think that is perfectly normal. I got a PS4 didn't break i'm happy.
Damn, I've been rumbled!You're just getting it to use as a foot rest, admit it![]()
It's actually because I'm a bit of a brat and I can't wait until March to get one. I was going to wait until InFamous was out but I just can't waitNo Dave, it's because you realise it's got a LOT more technical potential than the XBone and you can't resist it![]()
Erm, because I had 2 broken consoles and that didn't colour my judgement. I understand the point you're trying to make, but there is a lot more to go wrong in a console than in a TV. It's like saying that because my PC fails a few times I should jump onto an Apple or something.
Still, if you're happy with just your PS4, then that's fine. I just don't see the need for pointless digs at a console you don't even own![]()
About to upgrade to 1TB SSD, thought I may as well put it to use as it's just here doing nothing. Rather get it out of the way now than later, while there isn't a ton of data to transfer..
Just hope moving the console doesn't trigger off that HDMI fault lol. Once I've done this hopefully won't need to touch PS4 again until PS5![]()
Shouldn't i be able to take a dig at the console in a PS4 thread? It's not like i'm going into the Xbox thread to wind people up about the Xbox. I pointed out it's flaws to me i dont see anything wrong with that. On the other hand i dont see 1 flaw with the PS4 so far so i am obviously going to criticise the other console
Like i said before i would buy an Xbox if it was better but for me it's not.
snip
snip
with the videos uploaded to Facebook - can I save them from there locally and then re-host maybe at Youtube or something?
also images, im assuming I can capture an image - does this work the same way?
Genuine question why do people keep telling me there is little to no difference between the ps4 and Xbox one when there clearly is
Is it just a case of ignorance is bliss?
Anyone ?
Cause its not that clear, if you are having to ALWAYS put screen shots next to each other to tell the difference, then its not "clear".
.Cause its not that clear, if you are having to ALWAYS put screen shots next to each other to tell the difference, then its not "clear".
lol how else are you meant to illustrate the difference?
