Yes, some already are (COD & BF are good examples).
Higher resolution/ better performance
Serious question, where is the better performance?
Bit of an aggressive post considering people have only commented on the noise, and not strictly complained about it
Fact is the XO is quieter than the PS4, but that doesn't mean the PS4 is what you would call noisy.
Not really aggressive tbh is it - if that is what you consider aggressive, then I fear for you when you actually venture outside.
Fact is, the noise is irrelevant unless you actually stick your ear to the console.
Can't say I have noticed any noise with the PS4.
I will say this though the XBone is silent pretty much completely at all times from when I was over at my mates.
Of course it is silent because it is so under powered it doesn't produce any heat at max load.![]()
It is relevant if you can hear a noise that bothers you, no matter how close you are to the console
How much heat does the PS4 produce ?
Gets a bit warm... nothing to write home about.How much heat does the PS4 produce ?
Hmmm, girlfriend wants to pick me up a game for christmas but like theres just nothing that i really want lol. It would be between NBA 2k and knack most likely...maybe fifa even though i havent bought a football games in years.
.Ok I just tried to fix my ds4 r1 sticking. Pretty easy to fix but my trigger poped off.
So after I put it all back together. I started to notice not a lot of resistance in the right trigger.
Opened it up again to check and noticed that there was a tiny little spring missing....
Spent an hour with a torch trying to find it in the carpet with no luck. Was bout to give up and spotted that it somehow got stuck to the side of my chair.
So be careful if you decide to try and fix yours
