EVGA GeForce GTX 780 Ti Classified K|NGP|N Edition Announced – Fastest Card On The Planet
Status
Not open for further replies.
Caporegime
27 Nov 2005
Guernsey
Sorry if this has already been posted...
Features:
Up to 450W of Dedicated GPU Power – Dual 8pin + 6pin power input provides up to 450W of clean power.
14+3 Phase Power Design – 14 power phases for the GPU, and an additional 3 power phases for the memory.
EVGA ACX Cooling with 10CM Fans – K|NGP|N inspired cooling design featuring dual 10CM fans.
Bundled Backplate – Custom EVGA backplate included.
Separate PWM Baseplate – When going with extreme cooling on the GPU, it is still optimal to cool the PWMs. This separate baseplate allows you to keep the critical power section cool.
Enhancement PLL Circuitry – Optimized for extreme cooling.
Probelt with Bundled DMM Adapter and Status LEDs – Easy and precise monitoring of voltage health using external DMM. Onboard voltage status LEDs provide realtime voltage status for every critical rail.
Pitch Black High Flow I/O Bracket – Improved airflow with great aesthetics.
XOC Voltage Modification Points – Allows for extreme voltage tuning.
Read more at http://www.legitreviews.com/evga-ge...astest-card-planet_130645#15smCWEsdu6Vto3S.99
http://www.legitreviews.com/evga-ge...-edition-announced-fastest-card-planet_130645
http://www.evga.com/articles/00813/
Looks like the regular Classys were cast-offs from Kingpins after all? I didn't think there would be enough cherries to satisfy 2 products.
Although maybe the voltage controllers just aren't supported by Precision yet.
It was obvious this was going to happen. They've cashed in on Nvidia finally releasing a card that scales massively by releasing a higher tier product. Won't be buying a classified again now.
Although the BSOD issue seems with precision, but point still stands.
+1
EVGA Classified used to mean best of the best, in one silly move EVGA have trashed the brand.
Glad I decided to put my SC under water instead, money well spent and means I won't have to re-do the loop for maxwell.
Seems the price has gone up on them now too. When will the madness end :)
A Classy with the fixed BIOS running FireStrike
http://www.3dmark.com/fs/1305404
1. 14110. GFX Score 15576. 780. LN2 cooled. Physics Score 20035. CPU 3930K @ 5.6 LN2 cooled - 8 Pack - Link
2. 13172. GFX Score 14585. Tltan. Water cooled. Physics Score 19389. CPU 3960X @ 5.405 Water cooled - Newhit - Link
3. 13099. GFX Score 14653. 290X. Air cooled. Physics Score 18027. CPU 3960X @ 5.1 Air cooled - Jomama22 - Link
4. 12468. GFX Score 13825. Tltan. Water cooled. Physics Score 18027. CPU 3930K @ 5.0 Water cooled - Gregster - Link
5. 12314. GFX Score 13701. Tltan. Water cooled. Physics Score 17907. CPU 3930K @ 5.0 Water cooled - Whyscotty - Link
Status
