Sorry if this has already been posted...
http://www.evga.com/articles/00813/
http://www.legitreviews.com/evga-ge...-edition-announced-fastest-card-planet_130645Features:
Up to 450W of Dedicated GPU Power – Dual 8pin + 6pin power input provides up to 450W of clean power.
14+3 Phase Power Design – 14 power phases for the GPU, and an additional 3 power phases for the memory.
EVGA ACX Cooling with 10CM Fans – K|NGP|N inspired cooling design featuring dual 10CM fans.
Bundled Backplate – Custom EVGA backplate included.
Separate PWM Baseplate – When going with extreme cooling on the GPU, it is still optimal to cool the PWMs. This separate baseplate allows you to keep the critical power section cool.
Enhancement PLL Circuitry – Optimized for extreme cooling.
Probelt with Bundled DMM Adapter and Status LEDs – Easy and precise monitoring of voltage health using external DMM. Onboard voltage status LEDs provide realtime voltage status for every critical rail.
Pitch Black High Flow I/O Bracket – Improved airflow with great aesthetics.
XOC Voltage Modification Points – Allows for extreme voltage tuning.
Read more at http://www.legitreviews.com/evga-ge...astest-card-planet_130645#15smCWEsdu6Vto3S.99
