But there are just some rides I cannot get my head round. There was this thing [(I think) it's called an orbiter] with four or five arms which spin round in a horizonal circle and then go higher in the air and upside down. I went on it and it was pretty horrific. Then there was this other turbine ride called Gladiator Blizzard which went bloody high and upside down. Thankfully it broke before we got on it.
Orbiter's not that bad if it's the normal version with lap bars. If it was the dangly legs version with shoulder restraints, then yes these go higher and can be disorientating, but they're good when they run flat out at the end. The Gladiator Turbine is like a normal Booster ride except that the car turn so that it's out-facing. I can understand if it's a vertigo issue, but there are a lot higher rides then Booster and Turbine.
I won't go on any spinning teacup type ride as it just makes me sick.
Yeah, the set of teacups in Drayton Manor finished me off a few years back. Luckily I've been on most rides already at the point and it was mid-late afternoon, so not too much was lost. If you control your teacup against the ride's direction, then you'll do zig zags which is better than going with the ride's direction.
Went on one of those a few years ago and the G force was incredible, really did make me feel ill afterwards.
That machine was new only last year, so you probably went on a similar ride called Rock Rage (an Inversion 12) which came out in 2009. The picture you linked is called Atmosfear (a Loop Fighter).
I went on my first rollercoaster ride last year and it was called Rita, it's at Alton Towers.
Odd.. Rita is pretty tame for a rollercoaster.
Agree with MooMoo. Rita has the initial 4.7G pull, but it is otherwise a normal steel coaster. The Smiler, Oblivion and Nemesis are more options you can try for more adrenaline
All of them. I get no enjoyment from them. I'll go on them for the sake of it, I wont avoid anything unless I don't like the thought of it. It's not that I getting sick or I'm scared it's just they're boring and a waste of money.
Everyone is entitled to an opinion, but you very much sound like my old born-again Christian boss here who thinks that everything outside of the church is a waste of money
Nah, not that one. Star Flyer is the one i don't want to go on.
I guess it's a heights issue like with the Turbine, although I will admit that Star Flyer you linked is the tallest one in the country which is 70M. I went on it at the Nottingham Goose this year.
Crazy mouse and the booster on Brighton Pier are proper **** your pants scary. I have never been so ill after a ride. Ever!
Crazy Mouse? Surely you've been on Sonic at Alton Towers? The Mouse is way tame compared to Sonic, because the track on Sonic banks.
As for me, it's just the dodgems that I can't go on due to medical grounds. I lost an eye a while back and the remaining one is quite weak. 4G to 6G and high speeds in general are ok for me, where collisions involve higher G and can cause retinal damage. Can do all coasters, flats and water rides no probs. As for dying, you are more likely to die on the way to the theme park than actually being there.
