I look at itnot tried higher
I look at it
If it goes bang then there my excuse to upgrade to an i7-4770K.....![]()
Yes your using the Fire Strike Extreme settingsSomething is wrong here surely... GTX 780 getting ~20fps and a score of 4636?!
http://www.3dmark.com/3dm/1984812
Any thing I've done wrong? I've just gone form a 7950 to a 780 and installed the latest drivers/Nvidia software...
The benches with the Extreme settings are in this thread...http://forums.overclockers.co.uk/showthread.php?t=18487344
Yep right you are, I spotted the extreme thread but by 2am I wasn't so bothered...
I've just re run the test-9037
2500k @4.5GHz
780 @ 1006/1553
http://www.3dmark.com/3dm/1989529
Does that sound about right?
For those clocks, perfectly fine score and on the scoreboard![]()
OK thanks for that Greg, seems little underwhelming... My CPU is under water BTW![]()
Far to high.....
Think it was around 1.5v (Using only air cooling![]()
i7-2600k R.I.P.....I look at it
It was Strange as it died about 5 hours after I ran that benchmark while I was just browsing the net and it was at stock volts and at 1600mhz..lol Chaparral. I thought you was being rather brave going 1.5V on air![]()
