etc. just google msi afterburner skins
Yeah i think i might need to make mine more aggressive the top card reached 94c and started throttling after a while of playing bf4 online with silly high fps, this was with the fan profile i posted previously. The bottom card seemed ok at around 88-90c. If i had a bigger case i think id be ok.
I just set the power limit at +50%, though as we know this will not stop the card from thermal throttling if temps rise. Not sure about my vcore its possible but its not a very large core overclock so i doubt it.
EDIT
-0.062mv gave me a black screen while loading BF4 first time. -0.050mv seemed stable, but needs a long testing session.
I'm experimenting with reducing AUX voltage. I just tried -0.030mv and had no problems in BF4 and i did notice slightly lower temps. Will keep testing.
From what Unwinder says that's to do with memory bus (VDDCI) isn't it?
In the case, plenty of space to breathe.
That a Nice memory Bus Width & Bandwidth you have on the second one there..
I don't think it is to do with the memory, though im not 100% sure. Google says something about shader voltage.
Looking good Matt, good choice on the 290's.
Only problem is you're making me want to start tweaking and clocking mine, and I haven't got enough free time to actually do it!
Keep the info coming mate, it's all very much appreciated by those of us with less knowledge/skill/time/cojones.![]()
That a Nice memory Bus Width & Bandwidth you have on the second one there..![]()
Unwinder said:auxiliary voltage feeding
either memory bus (also known as VDDCI on AMD graphics cards) or PCIE bus
and crystal (PEXVDD on NVIDIA graphics cards)
Am I invisible?![]()
Haven't touched it yet, but I assume it works the same as PLL on a CPU, you experiment with moving it up/down and see if it helps with stability (AFAIK it's supposed to help keep the voltage stable).
http://en.wikipedia.org/wiki/Phase-locked_loop
Hi matt ~50-55% fan speed is enough to keep these cards at the rated clock speed. Some things that may be of use. (Most you probably know akready but just incase)
94deg = rated clock
95deg = lower clock
The cards can hit the rated clock at 94deg provided the fan speed has some head room.
My settings for 1 card were:
90deg target
70% max fan.
Its important for powertune to know that it has some fan speed to play with.
Although at these settings the fan will sitt around the 50-55% it wont get near 70% mark in bf4 and will be at the rated clock speed.
I would be wary reducing the core voltage for gaming as the memory voltage seems tied to it and as you found out can cause instability/blackscreen.
With 2 cards you might have a small difference but I did not use a custom fan profile as i didnt need it.
Basically with a custom fan profile if your max fan speed in powertune is still 55 it could be causing a drop in clocks . As even though you have set your fan to increase via afterburner powertune will not be aware of this.
Hope some of this is of help.
See I set mine to 90% in CCC with a max fan speed of 55%.
It hit 94/95ºC, the fan got to about 36% and the cards throttled. Now as far as I'm aware 55 is not the same as 36, but didn't stop it throttling.
I'm not having a go at you, simply that in my experience the default behaviour doesn't prevent throttling and it starts throttling before the fan gets to it's upper limit. Which to me means the system is broken.
