Silly question but what resolution is the test meant to be at?
Just run firestrike, no need to change anything.
No. Firestrike will render at 1080p anyways IIRC. your scores look like they should for GHz 7970s.
	I dont know, this is what I see in the details for the test i just ran.
Hmmm well guess you're right. Try to run 1080p then, thats the norm.
Weird that, maybe OP should update with some settings guidance like on the heaven 4.0 thread...
Its really not that hard dude lol, just make sure it runs at 1080p. And your score looks like its running at 1080p anyways so i dont see the issue.
Well like before, I think firestrike runs at native res, my native res is not 1080. So maybe a little guidance in the first post should say explicitly 1080p.
A nice guy called Skyn3t
Have a read up and better to get acquainted with it prior to going under water and that way, you will understand more of what you are doing
Read my "How to over volt a Titan or 780" link at the bottom of my sig. It is a little outdated but when you do it, I will point you in the right direction.
Because i honestly have nothing better to do....
1080 screen - http://www.3dmark.com/3dm/2031399
1440 screen - http://www.3dmark.com/3dm/2031463
1080:
1440:
My apologies for this thread being misleading and I will add that the test should be done at 1080P. I have both a 1440P monitor and a 1080P monitor and only ever noticed it runs at 1080P but better to have clarification![]()
