- 14 Feb 2011
With two 780 Ti's running. The last thing on your mind will be the Mantle piece.
You're rather missing the point of Mantle: it isn't to merely get better frame rates (although the early Mantle patches of existing graphics engines will concentrate on that) it's to make possible levels of complexity and detail that just isn't possible today, not even if you throw multpile 290Xs or 780s at it.
I highly recommend watching the presentation by the Oxide guys, who are working on a native Mantle supporting engine:
https://www.youtube.com/watch?v=QIWyf8Hyjbg&hd=1
Mantle is almost pointless on a 1440p crossfire 290X set up. You're going to have well in excess of 100-120 FPS in BF4 at max settings if you overclock them. And that's without Mantle. So considering the mass majority of monitors are 60 Hz at 1440p (some overclock to 90-100 Hz) then the extra frames from Mantle won't even get displayed on the monitor or make a difference really.You won't want the screen tearing generally so would be vsync capped. I can't game on my 1440p monitor with vsync off - it's horrendous. Even if I overclock it. My 120 Hz monitor never runs games with vsync on.
If it was single 290X vs 780Ti then sure factor Mantle in but I can't see it many much difference on a dual overclocked set up.
So my advice OP would be grab either a couple of 780s or 780Ti's. You aren't going to worrying about frame rates for a long time with those cards.
I would reason that 60 hz has been around for a long time and people still wanted more than 60fps. I would also say mantle is worth the risk or Dice and amd would not be pushing it so much. My main reason for the 290x was it's an amd game, water cooling and price. Yea the gtx780 is priced a little lower but the question was 290x or 780ti. If the gtx780 was in play then so is the 290p which costs less again and the same reasons apply.
The point was that running at 100 FPS will produce nasty screen tearing which is why most people frame cap or run with vsync on at 1440p/60Hz. People that want more FPS will largely be looking at 120 Hz monitors but the OP says he is 1440p. There is some increase in fluidity feeling by running at say 100 FPS on a 60 Hz screen but the screen tearing would nullify that IMO. So if Mantle boosts the FPS to 140 FPS it's largely pointless for somebody who doesn't game with vsync off.
I think it's your single card set ups which are really going to see the benefit from Mantle. Dual GPU is just going to pure grunt its way to the refresh rate of a 60 Hz monitor.
Why the gtx780 over the 290p or the gtx780ti over the 290x in this game then. All of them will produce great frame rates in dx11. Mantle should be better than dx11 and cooling is not an issue.
Because that was my recommendation. I have a 780 and it's been perfect for me just as my 7950s were previously.
I can't recommend AMD 290/X cards at the moment due to the black screen issue. If you'd like to recommend one then that's your choice![]()
That's fine by me was only taking you up on what you said above. There is nothing like a decent experience in the game with your own setup but i will say it's sli and crossfire that's in question and both seem to work really well in bf4. I wonder if mantle has any goodies for the crossfire user as well.
Last CF issue I had was with my 4850s. Last SLI issue I had was disabling Surround on multi-GPU on cards with different bios. Windows would crash.
They're both very robust nowadays.
What about dlc content and are you sure that will run above 60fps. Amd are and still are working with dice to support mantle in this game which for me is just a good reason to choose amd.
I have no doubt's both would do a really good job either way i just think the smart money on this game is with amd.
I don't know what the future holds but unless they add new settings in (which I doubt) then Mantle is really not going to make any difference in BF4 on a dual card overclocked set up.
I'm sure even 7950/70 CF pulls well over 60 FPS so 780Ti/290X level you've got tonnes in the tank.
I put black screen lottery as an issue overriding any positive at the moment I'm afraid. Support? You open the game and play it. You don't need support from AMD lol.
As the OP has asked between the two cards I'm sure he's aware of what they cost each.![]()
As title really, planning on getting a new PC and might watercool it also. Primary game would be BF4 so mantle interests me, but would I see any major difference between 2 of each card?
