working fine on an S4 here.
Did you get it from the Play store? Won't even let me download it on the Xperia T
Anyone else just see blonde bird in yellow robe on ps live
anyone tried these , my left stick is slightly worn but nothing to worry about yet , I thought I might just try these before it gets worse if it does.
http://www.shopto.net/video games/ps4/PS4AC15-ps4-analogue-thumb-grips
Do tell!
I think some of the streams are quite a good feature. What appeals to me is the thought that you can watch live gameplay footage before forking out for a naff game.
Do tell!
You're saying that I have to wait until it actually happens THEN I can complain?
Yes, as that's what normal people do, rather than complaining about something that may never happen.
Does anyone really watch that crap?
Did you get it from the Play store? Won't even let me download it on the Xperia T![]()
Please complain to both. The shop will most likely replace it but Sony are claiming there is no real issue with the pad... I. E. Not enough people have complained to them about it.
Keep the volume control box out the way of everything, I'm using mine plugged into the joypad as I do't have any av outputs to use.
I'm going to take mine back I think.
The sticky button issue is easy to fix, I've had it on both of my L1/R1 buttons. All you do is pop the button off with a pin/needle get a cotton bud and clean the two long square sections. My buttons are perfect now, it's just residue causing it to stick.
