R9 290X Owners Thread
Yes! I believe this is one of the possible reasons for the black screen bug. Set a manual fan profile in CCC or afterburner.
I've reported that bug to Thracks & AMD so they're aware of it. Are you on Windows 8?
http://i.imgur.com/dEtbWpY.jpg[IMG][/QUOTE]
Cheers for that, didn't know you could set a manual profile in Afterburner, so thanks.
On Windows 8.1, just tried to 13.11v9.5, see if that made a difference before making the profile, which it didn't, so I'll go back up to 13.12 now, and keep that manual profile.
It's only for a time being anyway, as I'll be putting together a custom water loop soon.
Good lad. I noticed it while back and reported it immediately.
I have started putting links to non ref 290X reviews in the OP, if anyone has any links to more reviews please post them here and I will put them in the OP.
Has anyone had any issues when using Flash player for sites like 4od or anything? This is my GPU usage when trying to watch something on 4od;
This all worked fine when I had my 7950, literally swapped out the card, and now having quite a few issues. I've removed and reinstalled drivers, and it doesn't seem to have done the trick. I've not got time tonight to fully investigate, 24 hour duty at work, so I'll be looking again tomorrow, but wondered if anyone had any quick idea what may be causing it. It happens in both Chrome and Firefox just for reference.
Disable hardware acceleration in chrome (advanced) settings. :)
Got two of these under water in my ocuk build that hopefully should come towards the end of the week or early next week. Looking forward to seeing what they can do.
hi all
i have a problem with my 290x in cf when gaming.
after an hour or less pc will shut down and reboot no bsod in event viewer it saying error 41 i have recently done a new build and the switch on my power supply no longer works,only way to turn off is remove plug completely not really a problem as pc runs 24/7
i have overclocked my cf in catalyst 15% power 10% gpu 12% memory no issue with heat max temp never hits 50 on either card my power is ok on the 3v,5v 12v is this overclock to high ? or is psu struggling for power ?
thanks in advance
hi all
thanks in advance
Sounds like a dodgy psu.
hi bit of stupid question.
if i install afterburner do i still keep catalyst installed and running,or uninstall it im actually not that happy with it anyway.
Got mine back in November, just didn't post here. Could you add me please (it's a HIS one)?
I got pretty unlucky, my first 290x was a screamer (massive coil whine) and had to go back. Second one (which I kept) isn't a great clocker and has a small amount of coil whine.
I can generally get the core to 1150 before it starts giving me grief in games. I can clock the memory to about 1400 for benchmarks but anything over stock causes black screens in games. It's nice and quiet though under water, and cool (55-60 degrees max with a 4770k in the loop).
The plan is to get a 1440p 120Hz monitor and another 290x at some point.
