Might try that but the end result looks a bit of a mess!
Use a drill bit, but before you do, masking tape over the hole so you don't scratch the rest.
What a drill bit without a drill?
I never saw you didn't have a drill lol. I would say to borrow one, but it's not always easy. If you own a set of small metal files, you could do that, but would take an age...
Tried to bore through it with a phillips screwdriver, almost broke the screwdriver and made absolutely no difference at all lol. Ill have to find a drill.
Smokefree.gov has a ‘Story Map’ up on their site, it’s a great little piece that allows anyone in the world to click an area on the map and share their quit story to help inspire others, lovely stuff.
You might think it’s odd that I’m mentioning this since Smokefree is so anti e-cigs (going so far as directly recommending avoiding them) but it’s heart warning to click through the markers and read (wait for it) story after story written by vapers that have switched away from cigarettes and have a better life for it.
http://allthejuices.com/smokefree-your-story-map
gog u can get a 20m roll for the same price here mate http://www.vape-atomizer-mesh.com/products/Kanthal-A1-Heat-Resistance-Wire---0.3mm--300-Micron-or--28-AWG----20-Metre-Spool-2436.html
and they nearly always throw in a few metres of a different size for free
Anyone looking to increase the airhole in their atties:
I take all of my kit that needs work to my local hardware & fastenings shop (family owned business) where the chap charges me a flat £5 workshop fee. It sounds dear to just drill a single hole, but some of the better atties have very thick, hard steel. My Aga-T2 ate 5 hardened drillbits (TiCobalt, iirc, at £17 a pop), just to drill one extra 1.2mm airhole AND increase the existing one.
I have also heard that the hcigar kayfun clones are the best quality.
But i have an Ephro clone from modsandatties and its been perfect for me so far
they are sold out now but the vape tank have some (ehpro ones)
http://www.thevapetank.co.uk/product/ehprokayfunliteplusclone
or here is the hcigar kayfun 3.1 clone
http://vapegeek.co.uk/Hcigar-Kayfun-31-78.htm
Anyone know anywhere in the Stoke-on-Trent area that does any decent juice? Best I've found is Totally Wicked but their not even that good...
