***The Vapers Lounge***
Status
Not open for further replies.
I never saw you didn't have a drill lol. I would say to borrow one, but it's not always easy. If you own a set of small metal files, you could do that, but would take an age...
Tried to bore through it with a phillips screwdriver, almost broke the screwdriver and made absolutely no difference at all lol. Ill have to find a drill.
When you get the drill, make sure you secure the atty properly and use a couple layers of masking tape to avoid scratching. My RSST has a scratch from not using enough tape. I also nearly went through the brand new kitchen worktop as I didn't secure the atty enough...
Smokefree.gov has a ‘Story Map’ up on their site, it’s a great little piece that allows anyone in the world to click an area on the map and share their quit story to help inspire others, lovely stuff.
You might think it’s odd that I’m mentioning this since Smokefree is so anti e-cigs (going so far as directly recommending avoiding them) but it’s heart warning to click through the markers and read (wait for it) story after story written by vapers that have switched away from cigarettes and have a better life for it.
http://allthejuices.com/smokefree-your-story-map
http://smokefree.gov/journey
Cheers lads. I'm going to go with the go4smoke link. Purely because they also do .30 kanthal at a reasonable price, which I'm sure will assist with microcoils on the KFL. Will post results with a variety of flavours as and when.
gog u can get a 20m roll for the same price here mate http://www.vape-atomizer-mesh.com/products/Kanthal-A1-Heat-Resistance-Wire---0.3mm--300-Micron-or--28-AWG----20-Metre-Spool-2436.html
and they nearly always throw in a few metres of a different size for free
The man speaks the truth! Ordered the £10 starter kit and got a few extra meters of wick chucked in, just wish I'd ordered some .25 and .30 kanthal as well though!
Hcigar Kayfun 3.1, Russian 91%, KayFunLite or Fogger V3. Honestly not really looking to spend out the full for the KFL but recommendations are appreciated.
Anyone looking to increase the airhole in their atties:
I take all of my kit that needs work to my local hardware & fastenings shop (family owned business) where the chap charges me a flat £5 workshop fee. It sounds dear to just drill a single hole, but some of the better atties have very thick, hard steel. My Aga-T2 ate 5 hardened drillbits (TiCobalt, iirc, at £17 a pop), just to drill one extra 1.2mm airhole AND increase the existing one. All that's needed is a pillar drill or drill press and a selection of small, good quality drillbits, which most independent hardware places should have (usually next to the key - cutter).
For more specialist work (from custom dripcans & topcaps, to machine finish or mirror polishing your existing kit), I send my stuff to a chap called Milo Dokic, aka Milo's Mods on Facebook. Top bloke, superb work and doesn't take the Mickey with his prices.
He's made me a custom brass topcap for my Aga-T2, a 22mm SS Topcap for my Igo-W (to fit perfectly on my JM22 mod) and a 23mm "Dripcan" (A high airflow topcap & drip tip in one piece, with dual 2mm air holes and 10mm wide driptip) designed for sub-ohm lung-inhales (don't attempt this in the car, it's a proper fog machine). Non-FB users can Trust me for his details.
:eek:
I have also heard that the hcigar kayfun clones are the best quality.
But i have an Ephro clone from modsandatties and its been perfect for me so far
they are sold out now but the vape tank have some (ehpro ones)
http://www.thevapetank.co.uk/product/ehprokayfunliteplusclone
or here is the hcigar kayfun 3.1 clone
http://vapegeek.co.uk/Hcigar-Kayfun-31-78.htm
I had also read that the HCigar clone was the one to go for, just wondering if anyone on here had any personal experiences. Shinyitis has definitely hit me I think.
Just received some Squid ink and Red Lady from Krakken, can reccomend them both, cant realy describe the Squid ink but it is nice and fruity, the Red Lady is Cherry flavoured but nicer than some of the generic cherry flavours I have tried in the past.
Status
