Cheers Matt, would I need a new PSU though?
Spec in sig.
Cheers
Should be ok as long as its a quality psu.
Spec in sig.
Cheers
tom d which ocz 550 is it?
So if I was to get a 780 I definitely wouldn't need a new PSU?
Thanks for all the help so far guys.
Hearing that 290's run hot and are loud I think I'd prefer a 780. (I really don't care about the whole AMD v Nvidia thing).
Which is the best 780 to go for then folks? I see lots of different variations on OcUK.
Well it's certainly a lot of money for a graphics card and I have recently upgraded, PC's don't come cheap!
But getting something like a 780 soon shouldn't warrant another upgrade for at least 12 months?
Tom you never mentioned what games you will be playing? Resolution of your monitor, settings desired etc.
Because at the moment I'm just playing a huge variety of games... They all run pretty well as it is but when I move to BF4 I know I'll be wanting better performance.
Ideally I want to run most things on full max and I use a res of 1920x1080.
Cheers
Getting a 290 makes far more sense. BF4 - Mantle - AMD. AMD pwn at BF4 and this is before Mantle.
Grab this 290, cheaper than ANY 780, faster than a 780, good cooler, quiet, will overclock like a champ.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-239-MS
If im wrong about any of the above, ill buy you a beer.![]()
I need to be 100% sure that will run with my PSU though. Seems to be a few split opinions here?
Also, that won't bottleneck my CPU will it like the 7850 did with my i3 3220?
