Thinking about converting my MTB with one of these Cyclotricity kits.
How big is the bottle battery? I can't seem to find any information on their site. My bike is a full sus and has less room in the triangle than a traditional bike.
if you get the converting kit from cyclotricity, make sure you get the £100 'pedal assist & LCD display' as you can de-restrict in few clicks![]()
Sorry for the slow reply, got slightly deluged by spam over the last couple of weeks, The limit can be increased to 40kph or reduced to increase the range. Given the natural limitations of a 250W motor I find it struggles to get past 33-35 kph on a full charge unless you’re going downhill where I’ve seen speeds as high as 45kph (one of the reasons I upgraded the front brakes so dramatically). The speed limiter is changed by entering the parameters mode… immediately after turning on the LCD, press and hold the up and down buttons together for a few seconds. A quick press of the power button takes you through the different options with the up/down buttons to change the settings… Press and hold the power button once finished to exit the parameters menu… I haven’t figured out what all of the different parameters are but One of them relates to wheel size, (20″, 26″, 29″, etc…), and one is for the motor speed limit (default 25). Increasing the speed limiter on ebikes should only ever be done when riding off-road or on private property, it’s illegal to ride de-restricted on the public highways.
)In the USA they have much more sensible size 750W motors on electric bikes, and speed limits of around 30mph. The EU limits are stupid as you cycle faster than 15 even without a motor, idiots!
HOWEVER another problem today.
Cycling through Stoke and my chain broke
This meant I had to make my way to work on choke only but it wouldn't carry me up my huge hill so I had to walk. The choke got me to work and all the way home so I was well happy.
The chain breakage was a bit of my own fault but I still emailed Cyclotricity to moan about my defective tyre, 3 ruined inner tubes and now my chain.
This afternoon Zak from Cyclotricity rang me and he is going to send me a much better Shimano chain + a 5 pack of inner tubes + a surprise.
Do these bikes not use hybrid energy from coasting or braking to recharge themselves?
Wow, I've done over 1,500 miles over the last year and never had a broken chain, and that's with a crank drive motor which puts a lot more force on the chain! I've not had a puncture either for that matter.
My bike can do 40+mph, get's me the 2.6 miles to work in 7 minutes and has no electric aid.
Keeps me fit too![]()
