I am having issues with the same coils. I have a protank 1 and protank 2 and i have nearly had to change the coils daily. With me they are getting flooded and causing ejuice to gurgle up to the mouth piece..as soon as i change the coil, problem gone. Going to look into rebuildables as this is a pain in the a$$
Just ordered a Russian 91% and looking at a Nemesis Clone and kick. Also ordered some juice, I thought this was meant to be cheaper than smoking?
Cheers for the input guys, pretty sure my spending will drop off after the Russian and I have a clean mod to carry around. Just been fun getting all the different bits together and messing around.
Came back to vaping recently after trying unsuccessfully last year - Have spent a fortune on various batteries, cartomizers, skycigs, SD kits, tanks, CE's, low ohm heads, high ohm heads, dripping atties etc etc and tried many truly horrible eliquids along the way.....End result it all ended in a big box and returning to my 20 a day L&B.
Getting closer this time though, my biggest breakthrough being *finally* discovering an eliquid that is *close* to a real ciggy! Or as close as I am likely to get anyway. Fair play to those who enjoy the sweet flavours but it's not for me. I never wanted to smoke a toffee apple and I really want to replicate as closely as possible my normal analogues.
So I am currently using with moderate success:
itaste V3 @ 8W
306 LR Dipping atty for use at home
Kanger mini protank 2 & evods with 1.8ohm heads for out and about (Draw is airy though)
Plastic drip tip as do not like the supplied metal tip
Triphammer Standard T&H 18mg - Closest I have found to a normal cigarette by a looooong way (Ordered some 24mg now to give a bit more throat hit)
HOL El Toro Cigarrillos (Not 100% on this yet as can taste the PG base? Leaving for a few days to steep)
Still duel fuelling but not beating myself up yet - It is a journey not a race.
Delighted though to have found the triphammer liquid - Tried the T&H Gold first time round and it was vile, far too sweet. The standard however really is very close to the real thing.
This to me ultimately is not about money or faffing about - I want as close as possible to pick up and forget with consistent performance and one flavour - i.e. the analogues!GUYS>>>>
my friend is looking to setup a website mainly selling batteries and such, he has being doing this for other products and is looking at getting to the ecig market.
can you advise on what batteries you guys would like to see on UK sites and a good price ?
Evening,
I want to quit again!
I had a evod ecig and I just got fed up with it leaking so I started smoking again.
Could you guys spec me something decent for around £30 would that be enough? Also something half decent for the wife. She's not that bothered about turning up the power or anything like that. Just something basic that won't leak like the last set did.
Thanks for any help
http://myepack.co.uk/mini-protank-2-kit.htmlEvening,
Thanks for any help
Or this one for better flavour...
greyhaze.co.uk/collections/ecig-starter-kits/products/aspire-bdc-maxi-e-cig-starter-kit
This looks okay, but the battery's are a bit small. Can use the bigger battery off my evod?
My old one had a 1000 or a 1100 with it and i used a 650 as well in the same day.
