X is contain. R1 + X is press and contain. Or a double press effectively. You use two defenders against one player. Never a good thing unless you get the ball.
Lol, didn't realize there was a 3rd button for defending
Lol, didn't realize there was a 3rd button for defending![]()
Okay guys, its got to the point where i genuinely want to help myself improve, i really enjoy the game but i continuosly see myself doing stupid stuff.
Firstly, what are some basics that will help me improve, dribbling, passing attacking and defending?
For example should i when defending, continouly sprint alongside the attacker? or hold down x to apply pressure or wait and stick in a tackle when i can see an oppertunity.
Another thing i do wrong is when attacking i always manage to lose the ball to his defence, i try to out manouver them and lose the ball.
What skill moves should i learn?
I just want to improve, if anyone can help me i will be forever grateful.
(PS. been trying the 3 square cross and its really good, cheers to who suggested i use it)
I also keep seeing people mention x when defending, what does that do? I either square(slide tackle) or O and pull their shirt, is there other ways of defending?
Yea' you could have scored some really sweaty goals, it's why I'm glad none of my crosses went in as I would have felt bad, although you did a spectacular early cross which was cool.
I might try and chance up formation a bit or as someone suggested run 4-3-3(4) but put it to defensive and mix it up a bit.
Also played this guy that went off at me because Neuer keeped making crazy saves... saying things like "youre ****. lucky *******. I'd rape you if it wasn't for Neuer. **** you you little ****."
Is there a way to mute mics permanently?
Played a kid that had his mic on. He went 1-0 up with a few minutes to go and seemed so happy.. then I scored on the 90th minute and I could actually hear him crying.
It's rare I hear anyone on the mic but I've received some rage messages that could probably get people arrested. I get mad as **** at fifa sometimes but at least I don't send sick rage messages.
Dribbling can mean two things;
A - Run straight up the wing to cross it then you need high pace and semi decent dribbling stats
B - Beating players by twisting in and out - then you need high dribbling stats and some skill moves
Passing;
You need to just think more quickly as what your currently doing most likely is taking too much time on the ball, rattle off a few ping pong passes to open up some space or use a zoomed out camera like co-op to switch the play to the opposite wing.
Defending;
You need good CB's and full backs this is really important pick from the below for your teams;
Ramos
IF Miranda
SIF Benatia
Chiellini
Silva
Dante
Hummels
etc, etc.
Try and use medium/medium full backs like
Enrique
Gibbs
Mariano
Konko
Radu
Schmelzer
etc, etc.
PS - it was me who posted about the triple tap cross a few days ago.
He's 2.25 at the moment. Have just seen 2 get bought out for that.
Sure mate, I'll be on tonight.I would like to give you a game sometime
If you use a headset I can give you some tips as we are playing.
cHk4, thats a pretty attacking middle you have there! Do you not get left open at all? I'm half tempted to drop Casemiro for Iniesta, hmm...
Put hunter on Iniesta, it's the one time I've actually noticed a big difference with a chem style on a player.
Thanks for replying mate.
Right now my defence is
CDM: Toure
LB: Cole
CB: David Luiz
CB: Vidic
LB: Zabaleta
Midfield and upfront i have
RM: Navas
LM: Schurrle
CAM: Rooney
ST: Eto
ST Jovetic
Any recommended skill moves to learn?
I know the flick right stick facing the opponent and then opposite way, heel chop?
I know the diagonal bottom left and right and i also know the one where your running down the wing but then you do a spin and cut inwards.
I usually have trouble getting through the enemys defense.
Unless you're good at skilling it usually ends up with you losing the ball. I wouldn't change anything if you're winning games without using them. Also when the game is even the slightest bit laggy skills seem to act erratically.
