- 11 Jan 2014
- West Yorkshire
hi mate, what is the full spec of your build?
you can,you have room,ram should be in the slot nearest the fan and the slot right at the end
just move the one on the left over one slot then try,if it still loops take out the gpu then try with mb graphics
might need latest bios to get the gpu working
so the ram should be in the 1st slot and the 4th slot, or the 2nd slot and 4th slot ? Im guessing the 2nd and 4th but in your first sentence you said it should in the slot nearest fan which is actually the first slot.
BTW is that Ram dated ? should i think about upgrading it to newer ram ?
p.s do you mean the i5 3570k?
