actually i think there are a couple of bent pins on the motherboard cpu bit
bugger, possible to fix ?
ok well gave it a go and promptly came to the conclusion that this is completely impossible to do, its near enough impossible to even see the singular pins let alone work out if you are bending them in the right direction.
return it and say the pins were bent when you opened the boxunless you bought it from overclockers then dont do that i am pretty sure a admin will ban me haha
