I know I'm likely right, I'll happily admit when I'm not.
I'll just have to wait till the tabloids post it so you can quote it on here for your own benefit
If you honestly believe that, that's hilarious.
I am not sure you are right, AMD have gone out of their way to assure people that there will be multivendor support. I think there will be, but, I don't think Nvidia will ever use it, unless it's a case of Mantle been so successful that they will have to use it.
Think of it just from an AMD point of view, if they are really want Mantle to succeed then they have to make it workable on many different types of GPU because if they don't then Mantle will only last as long as GCN lasts, which would be pretty stupid.
I agree with you, I don't think Nvidia is going anywhere and I don't think they will fail because of Mantle, but, if people back in 1997 predicted that 3DFX would fail in a few years because they didn't take up directx , they would have been laughed at too.
I dunno, there's a difference between ranting and trying to point out the bleeding obvious.
It's only your opinion though, it's not the "bleeding Obvious" Unless you can give me evidence that proves that Mantle will never be open and Nvidia will never use it.
