No Tueaudio for hd 7xxx??
No. Trueaudio was invented and put into chips after the 7xxx series.
All is explained. Follow the guide and we'll find out if your crossfire setup is working properly.
http://forums.overclockers.co.uk/showthread.php?t=18544020
Sadly all went well until I got to running the app within BF4 and it doesn't work. All settings checked, Crossfire working (which I knew) but I am unable to see frame rates or CPU usage in BF4, which seems to be a problem others are reporting (due to 64Bit it seems?) with the application you suggested.
Any options or advice welcomed?
I am a newb. at OCing so how can I do it for my cpu model? From BIOS should I change multiplier to 22.5 for 4.5Ghz? Should I change volts and/or NB as well?
Ask here. I've not owned an AMD CPU since the 2400+ Athlon XP processor.
Yeah I have exactly the same thought now.Audiotrak Prodigy is able to produce that sound in demo why do I need TrueAudio?I have dedicated music card.So we have the proprietary tech called "True Audio", which is cool, as AMD invented it but am I missing something? That demo sounds damned good (even if the fella gets on my nerves) and this is just using normal sound chips and headphones (I am using Sennheiser 333D G4me headphones). Why do we need True Audio when we can do it already? Wouldn't it be better to promote and use this already available and sounding great audio?
Gosh you had a blonde moment there? That demo is pre rendered before hand, so to do that in real time you have to have the exact same DSPs on your system and TA software. Realtime rendering of 3d sounds is high cost so that's why TA is a good thing. Playback however is very different as it is already rendered but now only output for playing it back to you.Yeah I have exactly the same thought now.Audiotrak Prodigy is able to produce that sound in demo why do I need TrueAudio?I have dedicated music card.
With true audio when I connect HDMI to gpu will I get sound on my TV?
My bad brotha. I forgot you need the latest beta of riva tuner OSD for it to work in BF4. This version has 64 bit support. Uninstall Rivatuner Statistics Server first, then install this version.
http://archive.sunet.se/pub/games/PC/guru3d/rtss/RTSSSetup600Beta4-Guru3d.rar
Sadly still no joy here. What I get now is a flashing bar down the left hand side of the screen, around an inch wide, running top to bottom![]()
You have selected 64bit in Riva Tuner?
