- 30 Nov 2011
I think youve anzwered your own question then
Wait a minute, isn't that a bit like saying ;
Ferrari 458 Spider - check
V8 engine - check
Budget tyres - check
Hi will i really see a big improvement over my Asus Pb278q?
I'd still prefer to see this in person it being a TN panel. I'm aware that the variability of quality across TN displays is much larger than the variability in IPS displays and so this ASUS model could be very nice and not much different quality to your typical IPS, but the TN aspect still worries me and so it would be much better for me, personally, to see this thing first hand.
An improvement when doing what? It's a very different monitor. Different panel type, different limitations and different relative strengths.
if TFTCentral or pcmonitors.info give it a good review then I'll be willing to spend the potential return postage to give one a shot
they go right in to measuring actual contrast, colour balance, calibration, ghosting, viewing angles... everything you would really want to know
Im gonna be down for one of these
I know info is probably pretty thin on the ground but does anybody know if this will work with a gtx780 as main pc and also a vga input from another machine? (Two machines sharing one monitor) would probably have to get a kvm type deal but what one would suit this? Also could the vga pc has the res set at 1080p and play some older games and still look good? I assume as the aspect ratio of 1440p and 1080p are the same should be ok
Hope we get some solid uk release date on these soon
This monitor only has a DisplayPort input for video signals.
Can anyone make an educated guess as to when these will be available to review channels?
Thanks but is there not a vga to displayport adaptor? And is it just the one input it has do you know?
There is only one single DP input. No other inputs can be used because G-SYNC requires data packets which only DP support. You can convert a DisplayPort signal to VGA but not the other way around. This monitor is pure DisplayPort. Plus some non-video ports like USB 3.0.
