** JANUARY SALE: AMD/NVIDIA GRAPHICS CARDS & POWER SUPPLIES!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OK these prices will end at end of this month (next Wednesday if on THIS WEEK ONLY) or when stock runs out, whichever comes first, we expect some to sell out fast. I am also including some great power supply deals too.
So whether your gaming or mining, check these deals out:-
Asus Radeon R9 290 "Voltage Unlocked" 4096MB GDDR5 PCI-Express Graphics Card @ £319.99 inc VAT
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Was [£349.95] Inc. VAT
Only £319.99 inc VAT.
ORDER NOW
Gigabyte Radeon R9 290X OC WindForce 4096MB GDDR5 PCI-Express Graphics Card (GV-R929XOC-4GD) @ £429.95 inc VAT
Keeping the same 450W Cooling capacity using only 2 slots, the New WINDFORCE 3X 450W cooling system is equipped with two 8mm and four 6mm cooper heat-pipes , inclined fans, and GIGABYTE “Triangle Cool” technology. This not only provides an effective heat dissipation capacity but also enables higher performance due to a lower temperature.
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up MONITORING, GPU CLOCK, MEMORY CLOCK,FAN, OSD, ONLINE SUPPORT and update driver, BIOS directly.
Supporting multiple independent display outputs simultaneously, AMD Eyefinity technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
Features:-
- WINDFORCE 3X 450W cooling system
- Core Clock: 1040MHz
Specification
- GPU: Hawaii XT
- Litecoin Hash Rate: 850-1000
- Stream Processors: 2816
- Core Speed: 1040MHz
- Memory Speed: 5000Mhz
- Memory interface: 512-Bit>
- Memory capacity: 4096MB GDDR5
- Cooling: WindForce 3X 450W Cooling System
- PCI-Express X16 lane required
- 600W or greater PSU required
- Power Connectors: 8-pin + 6-pin required <br />
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort <br />
- Card size: L=294mm, W=141mm, H=41mm
- Warranty: 3yr
Was [£469.99] Inc. VAT
Only £429.95 inc VAT.
ORDER NOW
MSI Radeon R9 290 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £349.99 inc VAT
Was [£371.99] Inc. VAT
Only £349.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 290 4096MB GDDR5 PCI-Express Graphics Card with Battlefield 4 PC Game @ £319.99 inc VAT
Was [£335.99] Inc. VAT
ORDER NOW
Powercolor Radeon R9 290X 4096MB GDDR5 PCI-Express Graphics Card with Battlefield 4 PC Game @ £399.95 inc VAT
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Was [£409.99] Inc. VAT
Only £399.95 inc VAT.
ORDER NOW
Sapphire Radeon R9 290X Tri-X "BF4 Edition" 4096MB GDDR5 PCI-Express Graphics Card (11226-00-50G) @ £449.99 inc VAT
Was [£499.99] Inc. VAT
Only £449.99 inc VAT.
ORDER NOW
Asus Radeon R9 280X DirectCUII OC 3072MB GDDR5 PCI-Express Graphics Card @ £259.99 inc VAT
The next generation Asus R9 280X DC2 graphics card has arrived, fitted with a 28nm GPU that packs 4.3bn transistors and is combined with 3GB GDDR5 Memory, it provides users with the speed for smoother gaming. Supporting full DirectX 11, AMD CrossFireX and AMD HD3D, the GPU includes an exclusive tweak utility which allows users to tune the performance of up to four graphics cards and check card status via an intuitive interface.
This GPU Tweak function links the GPU clock frequency to the voltage, so as you scale the GPU clock the voltage automatically follows; a useful tool for inexperienced Overclockers, It also enables users to select between 2D and 3D mode by providing the ability to change the respective clock speeds, voltages and fan speeds of either. Disabling the 2D mode also forces the faster 3D mode, stabilising overclocking and benchmarking results.
Embedded with GPU-Z to access accurate graphics card information, the card also contains a live update driver and BIOS benefiting users with the ability to keep their card in the best condition. Widget monitoring provides the choice to display the most needed information including a full widget, light widget or real time monitoring.
Furthermore, new PCI Express 3.0 delivers improved encoding and twice the performance of the previous PCI Express 2.0 and vision horizons can be expanded across six displays with AMD Eyefinity technology. This technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
Specification:-
- Litecoin Hash Rate: 550-750
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Core Clock Speed: 850MHz (1000MHz Boost)
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 6000MHz
- Load / Idle Board Power: <300W / <3W
- Display Outputs: 2x DVI + 1x DP + 1x HDMI
- Power: 250W TDP
- 3yr Warranty
Was [£275.99] Inc. VAT
Only £259.99 inc VAT.
ORDER NOW
Asus Radeon R9 280X DirectCUII TOP 3072MB GDDR5 PCI-Express Graphics Card @ £289.99 inc VAT
The next generation Asus R9 280X DC2T graphics card has arrived, fitted with a 28nm GPU that packs 4.3bn transistors and is combined with 3GB GDDR5 Memory, it provides users with the speed for smoother gaming. Supporting full DirectX 11, AMD CrossFireX and AMD HD3D, the GPU includes an exclusive tweak utility which allows users to tune the performance of up to four graphics cards and check card status via an intuitive interface.
Specification:-
- Core Clock Speed: 1070MHz
- Memory Width / Speed: 384 bit / 6400MHz
- Power: 250W TDP
- 3yr Warranty
Was [£299.99] Inc. VAT
Only £289.99 inc VAT.
ORDER NOW
Gigabyte Radeon R9 280X Rev2.0 WindForce 3X OC 3072MB GDDR5 PCI-Express Graphics Card with Battlefield 4 PC Game @ £259.99 inc VAT
GIGABYTE introduces the latest exclusive "Triangle Cool" Technology to reach a better cooling performance. The latest patent pending technology combines fin with clip module in a special triangle shape. With the original anti-turbulence structure plus the new triangle cooling design, it enhances the efficiency of heat dissipation dramatically by minimizing the flow of turbulence between fans. Therefore, the "Triangle Cool" Technology provides a more efficient air flow for the cooling system.
Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. GIGABYTE Ultra Durable VGA can lower GPU temperature by 5% to 10%.
Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. GIGABYTE Ultra Durable VGA graphic accelerators improve overclocking capability by 10% to 30%.
Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency. GIGABYTE Ultra Durable VGA can lower power switching loss by 10% to 30%.
Specification:-
- Rev2.0
- Black PCB
- Core Clock Speed: 1000MHz
- Boost Clock Speed: 1100MHz
- Display Outputs: 1x DVI + 2x Mini-DP + 1x HDMI
- Power: 250W TDP
- 3yr Warranty
ORDER NOW
MSI Radeon R9 280X Gaming Edition LE 3072MB GDDR5 PCI-Express Graphics Card @ £229.99 inc VAT
The AMD Radeon™ R9 280X graphics processor harnesses visionary GCN Architecture. This GPU is primed to enable astonishing performance and breathtaking image quality, making it a top choice for gamers who expect the best.
Was [£239.99] Inc. VAT
Only £229.99 inc VAT.
ORDER NOW
MSI Radeon R9 280X Gaming Edition OC 3072MB GDDR5 PCI-Express Graphics Card @ £245.99 inc VAT
Only £245.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 280X TurboDUO "BF4 Edition" 3072MB GDDR5 PCI-Express Graphics Card @ £239.99 inc VAT
Powercolor R9 280X has the performance to power the latest games with ease but at a very aggressive price point making it incredible value for money.
Equipped with TurboDUO near silent cooling solution meaning you can game in near silence whilst keeping the card nice and cool.
Features:-
- Multi Phase Design: 8 Power Phases for improved OC ability
- Digital PWM
- Ferrite Core Choke: Decreases ripple to deliver more stable voltage
- DirectFET
- Patent GSG- Shape Heat Pipes Design: Reduces temperatures by upto 17% and noise reduction of upto 19%
- Pure Copper Base
- Backplate included
Specification:-
- Core Clock Speed: 880MHz
- Boost Clock Speed: 1030MHz
- Power: 250W TDP
- 2yr Warranty
Was [£249.95] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
Gigabyte Radeon R9 270X WindForce 3X OC 2048MB GDDR5 PCI-Express Graphics Card with BattleField 4 PC Game Included @ £149.99 inc VAT
Specification:-
- Litecoin Hash Rate: 350-500
- Core Clock Speed: 1050MHz
- Stream Processors: 1280
- Frame Buffer / Memory: 2GB GDDR5
- Memory Width / Speed: 256 bit / 5600MHz
- Power Connectors: 6-pin + 6-pin
- Power: 180W TDP
- 3yr Warranty
Was [£161.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Gigabyte Radeon R9 270X WindForce 3X OC 4096MB GDDR5 PCI-Express Graphics Card @ £167.99 inc VAT
Specification:-
- Power: 180W TDP
- 3yr Warranty
Was [£179.99] Inc. VAT
Only £167.99 inc VAT.
ORDER NOW
MSI Radeon R9 270 Gaming Edition OC 2048MB GDDR5 PCI-Express Graphics Card @ £127.99 inc VAT **BEST VALUE GAMING GRAPHICS CARD**
You’ve heard it before: no guts, no glory. Now you’ve got both. With the power to drive today’s hottest games — and tomorrow’s — Radeon™ R9 270 graphics keep you in the fight whatever the circumstances.
Was [£139.99] Inc. VAT
Only £127.99 inc VAT - BEST VALUE FOR MONEY GAMING CARD!!
ORDER NOW
MSI Radeon R9 270X Gaming Edition OC 2048MB GDDR5 PCI-Express Graphics Card @ £149.99 inc VAT
You’ve heard it before: no guts, no glory. Now you’ve got both. With the power to drive today’s hottest games — and tomorrow’s — Radeon™ R9 270X graphics keep you in the fight whatever the circumstances.
Was [£155.99] Inc. VAT
ORDER NOW
MSI Radeon R9 270X Gaming Edition OC 4096MB GDDR5 PCI-Express Graphics Card @ £169.99 inc VAT
A graphics card is the single most important element for more FPS. As gamers, we understand that not just any graphics card "will do". That's why we bring you the best of the best. We don't want to bug you with noise and heat, but we DO want to give you more performance. With MSI GAMING series graphics cards you get just that.
Most MSI Gaming graphics cards come pre-overclocked out of the factory. This simply means you get more performance out of your card, without spending any time on checking for maximum clocks and stability. Pre-overclocked graphics cards simply give more performance and you don't have to worry about damaging your card, it is completely covered by our warranty!
MSI's Twin Frozr has been the industry defining graphics card cooler. The first Twin Frozr kicked of the dual-fan trend and today MSI stays true to its dual-fan dual-slot design where others have to resort to less effective means.
The other part that the Twin Frozr cooler uses is a large Aluminium fin grid array that provides a huge amount of surface area for cooling. Heat from the GPU is transferred to the fin grid array by virtue of heat pipes with MSI's special SuperPipe technology. SuperPipes transfer heat twice as fast as regular heat pipes enabling an MSI GAMING graphics card to stay cooler than the competition.
Futhermore, MSI provide all new Airflow Control technology on Twin Frozr. This new thermal tech. is leading airflow to heat pipe by spcial deflector on heatsink, so it can deflect more airflow to heat pipes directly. In addtion,This exclusive heatsink design is increasing the area of heatsink so that enhancing the efficiency of dissipation much more.
Specification:-
- Core Clock Speed: 1030MHz
- Boost Clock Speed: 1120MHz
- Frame Buffer / Memory: 4GB GDDR5
- Power: 180W TDP
- 3yr Warranty
Only £169.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 270X "PowerBank" 2048MB GDDR5 PCI-Express Graphics Card @ £149.99 inc VAT
The Powercolor R9 270X is supplied with a FREE Powerbank, this device is essentially a high quality portable battery which can be used to re-charge mobile phones, tablets etc.
The latest PCS+ R9 270X is factory overclocked to 1060MHz, which is 60MHz higher than reference design, even up to 1100MHz with boost, offering and delivering class leading performance. The new model is fitted with 2GB of GDDR5 memory connected via high performance 256-bit memory interface, delivering excellent computing performance.
The PCS+ R9 270X is packed with Gold Power kit, which includes Digital PWM, Ferrite Conducting Power (FCP), and Multi Phase Design, ensures power efficiency and stability at OC mode. The exclusive PCS+ cooling design is formed with 90mm ultra huge dual fan, 3pcs of large heat pipes, enormous surface of cooling fin and pure copper base, delivering 16% cooler than reference design. What’s more, we adopts the patent Double Blades fan design at PCS+ R9 270X, successfully increase 20% more airflow, even prevent the dust depositing at the bearings and the bottom of fan, prolonging the life cycle of the thermal as well as video card.
Specification:-
- Core Clock Speed: 1060MHz
- Core Boost Speed: 1100MHz
- Memory Width / Speed: 256 bit / 5700MHz
- Display Outputs: 2x DVI + 2x Mini-DP + 1x HDMI
- Power: 180W TDP
- 2yr Warranty
ORDER NOW
Powercolor Radeon R9 270X DEVIL 2048MB GDDR5 PCI-Express Graphics Card @ £157.99 inc VAT
The Devil R9 270X is totally designed for enthusiastic gamers with factory overclock to 1150MHz, even up to 1180MHz with boost, delivering the most tremendous performance at its class. Also, the Devil R9 270X is equipped with 2GB of GDDR5, also with 1280 stream processors and high speed 256-bit memory interface, delivering excellent computing performance.
Devil R9 270X is built with Platinum Power Kit, which includes the most deluxe material like DirectFET, Digital PWM and 7+1+1 phases, dramatically improve total stability and reliable power delivery to GPU. The new Devil uses trio fans design, together with 4 units heat pipes and large surface of aluminum cooling fin, delivering 25% cooler and 18% quieter than reference.
To make Devil’s users feel more unique than others, we designed an exclusive interface for Powerup Tuner using Devil theme, also a Devil Gaming Pad, offering users a complete Devil package to choose.
Features:-
- Multi Phase Design: 7+1+1 Phases design enhances power efficiency and stability
- EMI Shell: Excellent interference suppression for high frequency and low leakage current.
- Digital PWM: Can work at higher frequency improving OC ability
- Super Capacitors: Excellent noise, temperature performance at GHz frequency, ultra low ESR.
- UHB: Featuring ultra high frequency which decrease ripple to deliver extreme stable voltage power.
- Efficient Triple fan design
- Includes Devil Gaming Pad
Specification:-
- Core Clock Speed: 1150MHz
- Core Boost Speed: 1180MHz
- Power: 180W TDP
- 2yr Warranty
- Product Review 1: http://www.custompcreview.com/reviews/powercolor-devil-r9-270x-2gb-review/19285/
- Product Review 2: http://www.overclockersclub.com/reviews/powercolor_devil_r9_270x/
- Product Review 3: http://www.hitechlegion.com/reviews/graphics/37917-pc-270x-dev?showall=1&limitstart
Was [£169.99] Inc. VAT
Only £157.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 270X Boost OC 2048MB GDDR5 PCI-Express Card @ £149.99 inc VAT
The "dual" in Dual-X refers to the two highly advanced cooling fans that are coupled with multi-heatpipe technology to cool mid-to high-end graphics cards. The fans are amazing: each blade boasts a sleek airfoil shape that increases cool air throughput so they can run slower. Even when you're pushing the processing power to the limits. Even when your're overclocking.
The quiet-running fans work with multi-heatpipes and heatsinks that take away heat from the processor to the fans. Plus, dust repelling bearings radically reduce failure caused by the build-up of dirt. In short, its a quiet, efficient way of cooling your graphics card - even when you're pushing it to the limits.
Specification:-
- Core Clock Speed: 1020MHz
- Core Boost Speed: 1070MHz
- Power: 180W TDP
- 2yr Warranty
ORDER NOW
Sapphire Radeon R9 270X Boost OC 4096MB GDDR5 PCI-Express Card @ £164.99 inc VAT
Specification:-
- Power: 180W TDP
- 2yr Warranty
Only £164.99 inc VAT.
ORDER NOW
Sapphire Radeon R7 260X OC 2048MB GDDR5 PCI-Express Graphics Card (11222-06-20G) @ £99.95 inc VAT
The new AMD R260X is the ultimate do it all card, great for media streaming, gaming and featuring AMD's new True HD Audio sound, which is only available on R7 260 and R9 290 models.
Specification:-
- Stream Processors: 896
- Memory Width / Speed: 128 bit / 6600MHz
- Display Outputs: 2x DVI + 1x HDMI + 1x DisplayPort
- Power: 115W TDP
- 2yr Warranty
Was [£119.99] Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
HIS HD 7970 IceQ X² 3072MB GDDR5 PCI-Express Graphics Card (H797QM3G2M) @ £259.99 inc VAT
Hightech Information System (HIS) today announced the launch of HIS 7970 IceQ X² 3GB. This world’s fastest card with single GPU is cooler and quieter with the innovative and performance-leading IceQ X² solution. The card also has better OC capability and longer life span with HIS high quality component.
With IceQ X², the card is up to 17 °C cooler than the reference cooler. The super large 2x 8.9cm dual axial fans draws massive amount of cool air to cool the GPU directly. The fan is extremely durable with a life span of up to 50,000 hours. 3x 6mm and 2x 8mm wide heatpipes optimize cooling performance by removing heat from the core area. The extra large 40x47.5mm copper heatsink provides a large area to dissipate heat efficiently. The card also carries memory and mosfet heat sinks to provide extra heat dissipation from these areas. The card also features fan control and monitoring, you are able to read fan speed & Asic temperature from CCC or software.
IceQ X² is one of the quietest coolers. The card is below 28dB when watching movies, surfing Facebook, working. The card is quiet in 2D mode and remains quiet whether you are gaming, online socializing, entertaining or working. The card is up to 15dB quieter than the reference cooler.
iTurbo is your software assistant to control your graphics card to be quiet, cool and experiece overclocking by simply pressing the iTurbo Button! User Friendly Overclocking Software: Cooler, Quiter, OC! iTurbo's Fan Control and Fan Monitoring allow easy adjustment of your card to its maximum cooling performance or to run your card quietly!
Press iTurbo: OC Right Away!
With the smart auto overclocking function, users can experience a slight performance boost for selected HIS graphic cards with just one click!
Powerful Overclocking Software
Specification:-
- Vastly cooler running than previous generation
- Quieter running than previous generation
- Compute Power: 3.5 TFLOPS
- Core Clock Speed: 925MHz
- Primitive Rate: 2 prim / clk
- Memory Width / Speed: 384 bit / 5500MHz
- Display Outputs: 1xDVI + 2x mDP + 1x HDMI
- 2yr Warranty
ORDER NOW
Gainward GeForce GTX Titan 6144MB GDDR5 PCI-Express Graphics Card @ £779.99 inc VAT
The worlds most powerful single GPU graphics card!
- GPU: GeForce GTX TITAN
- Core Base Clock: 837 MHz
- Core Boost Clock: 876 MHz
- Memory Clock: 6008 MHz
- Memory Size: 6144MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2688
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Was [£899.99] Inc. VAT
Only £779.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 780Ti Superclock 3072MB GDDR5 PCI-Express Graphics Card (03G-P4-2883-KR) @ £587.99 inc VAT
nonl2br
<p align="left">
NVIDIA's latest Geforce 780Ti takes the fight right to the competition in the battle for current worlds fastest single GPU. Packing a fully enabled GK110 GPU with a whopping 2880 cuda cores this card has huge amounts of processing power to enable it to power through any game. Infact the 780 Ti is so impressive, it’s not just cheaper than TITAN, it beats it in performance and takes the crown as the Best Gaming GPU on the Planet.
</p>
<p align="left">
NVIDIA are supporting the overclocking community even further with an advanced three rail PWM with load balancing, whereas older GTX 780 and Titan pulled all their power through three rails, they did not load balance. 780Ti's new PWM means it can source power from three sources and load balance resulting in the same amount of power from each rail, allowing for more superior overclocks and stability. Here at Overclockers UK we tested this and where we found Titans would top out at 1100-1150MHz core, whereas the 780Ti was able to hit 1200-1300Mhz core over and over again, proving this new PWM not only offers efficiency and stability, but also great overclocking ability. When overclocked this cards performance can be increased by upto a further 30%, making it a truly unstoppable force.
</p>
<p align="left">
For memory once again here at Overclockers UK we are very impressed to see 3GB of RAM and a 384-Bit interface meaning it can power the latest games even at the highest resolutions and detail settings, making this card the perfect choice for any gamer or overclocker.
</p>
<p align="left">
780Ti uses the Titan cooling system and this means that even whilst gaming, you can indeed game in silence or at night whilst the rest of the household is asleep and not have to worry about waking up those sleeping.
</p>
<br />
<center>
<object width="640" height="360"><param name="movie" value="//www.youtube.com/v/OHlQnKTvGms?version=3&amp;hl=en_GB&amp;rel=0"></param><param name="allowFullScreen" value="false"></param><param name="allowscriptaccess" value="always"></param>
<embed src="//www.youtube.com/v/OHlQnKTvGms?version=3&amp;hl=en_GB&amp;rel=0" type="application/x-shockwave-flash" width="640" height="360" allowscriptaccess="always" allowfullscreen="false"></embed></object>
</center>
<br />
<br />
<p align="left">
<h1>Specification</h1>
<b>GeForce GTX 780Ti</b><br />
- GPU: GeForce GTX 780Ti (GK110)<br />
- Core Base Clock: 980MHz<br />
- Core Boost Clock: 1046MHz <br />
- Memory Clock: 7000MHz <br />
- Memory Size: 3072MB GDDR5<br />
- Bus Type: PCI Express 3.0<br />
- Memory Bus: 384-bit<br />
- CUDA Cores: 2880<br />
- DirectX 11.2: Yes<br />
- DVI Port: DVI-I /DVI-D<br />
- DisplayPort: Yes <br />
- HDCP: Yes<br />
- HDMI: Yes<br />
- Warranty: 3yr
</p>
<p align="left">
<b>Features</b><br />
- MAX your overclocks with NVIDIA's Power Balancing<br />
- A WHOPPING 2880 CUDA Cores (Fully enabled GK110)<br />
- GPU Boost 2.0 Technology<br />
- TITAN cooling system
</p>
Was [£599.99] Inc. VAT
Only £587.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 780Ti Superclock ACX 3072MB GDDR5 PCI-Express Graphics Card (03G-P4-2884-KR) @ £587.99 inc VAT
nonl2br
<p align="left">
The EVGA GeForce GTX 780 Ti is the best gaming GPU on the planet, delivering 25% more cores and exciting new technologies to take extreme gaming to a whole new level. This is pure performance accelerated, giving you the freedom to play every title at ultra settings and max resolutions on today's highest-definition displays.
</p>
<p align="left">
Boost your gaming experience with a stunningly beautiful, quiet design. You get NVIDIA GPU Boost 2.0 for maximum clock speeds, PhysX and TXAA technologies for smooth, sharp graphics, and GeForce ShadowPlay to capture all your greatest gaming moments, automatically. Whether you're playing on stunning 4K monitors at extreme settings, or multiple monitors at 2560x1600, the GTX 780 Ti provides the horsepower to drive all your next-gen gaming visual experiences.
</p>
<p align="left">
Of course, when paired up with EVGA's Award Winning ACX Cooling, you get reduced temperatures, silent operation, and best of all, unbelievable overclocking potential!
</p>
<br />
<center>
</center>
<br />
<br />
<p align="left">
- Core Base Clock: 1006MHz<br />
- Core Boost Clock: 1072MHz <br />
- HDCP: Yes<br />
- HDMI: Yes<br />
- Warranty: 3yr
</p>
<p align="left">
</p>
ORDER NOW
Gainward GeForce GTX 780Ti Phantom 3072MB GDDR5 PCI-Express Graphics Card @ £539.99 inc VAT
nonl2br
<p align="left">
</p>
<p align="left">
</p>
<p align="left">
</p>
<p align="left">
</p>
<br />
<center>
</center>
<br />
<br />
<p align="left">
- HDCP: Yes<br />
- HDMI: Yes<br />
- Warranty: 2yr
</p>
<p align="left">
</p>
Was [£559.99] Inc. VAT
Only £539.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 780Ti WindForce 3x OC 3072MB GDDR5 PCI-Express Graphics Card (GV-N78TOC-3GD) @ £539.99 inc VAT
nonl2br
<p align="left">
GIGABYTE, the world leader in high-performance gaming hardware and system, is pleased to announce the latest graphics card, GeForce GTX 780 Ti Overclock Edition (GV-N78TOC-3GD). With 25% plus CUDA cores than GTX 780, the most powerful thermal design in the world and exciting new technologies, GV-N78TOC-3GD is going to bring all the gamers an extremely gaming experience to a whole new level. The exclusive WINDFORCE 3X cooling design guarantees you to dissipate 450 watt heat out. Enjoy your game play with a stunningly beautiful and quiet design is no longer a dream. It also supports OC GURU II and GPU Boost 2.0 for maximum clock speeds. GV-N78TOC-3GD features PhysX® and TXAA™ technologies for smooth, sharp graphics, and GeForce ShadowPlay™ to capture all your greatest gaming moments automatically. Whether you play on 4K monitors at extreme settings, GV-N78TOC-3GD can provide the horsepower to drive all your next-gen gaming visual experiences.
</p>
<p align="left">
GIGABYTE innovatively presents WINDFORCE 3X 2-SLOT cooling system, thinner and cooler! The thermal structure contains three ultra quiet PWM fans, an only 2-slot height heat sink with exclusive "Triangle Cool" Technology, two 8mm and four 6mm cooper heat pipes and a high-performance RAM heatsink.
</p>
<p align="left">
The innovative thermal design guarantees the heat dissipation capability to over 450watt. The cooling performance is 14% significantly better than stock fan! WINDFORCE 3X 450W cooling system not only provides an effective heat dissipation capacity, but also gained a higher performance with lower GPU temperature through the GPU Boost 2.0 technology.
</p>
<p align="left">
According to the latest NVIDIA® technology, GPU BOOST 2.0, GV-N78TOC-3GD provides gamers an unlimited overclocking capability. By using GIGABYTE exclusive OC GURU II, gamers can monitor and adjust all important settings such as GPU clock, memory clock, fan speed, voltage, power target, OSD and online support. With the upgrade and easy-to-control user interface, GIGABYTE OC GURU II becomes the best mate while using GV-N78TOC-3GD.
</p>
<br />
<center>
</center>
<br />
<br />
<p align="left">
- Core Base Clock: 1020MHz<br />
- Core Boost Clock: 1085MHz <br />
- HDCP: Yes<br />
- HDMI: Yes<br />
- Warranty: 3yr
</p>
<p align="left">
</p>
ORDER NOW
Inno3D GeForce GTX 780Ti 3072MB GDDR5 PCI-Express Graphics Card (N78T-1DDN-L5HS) @ £509.99 inc VAT
nonl2br
<p align="left">
</p>
<p align="left">
</p>
<p align="left">
</p>
<p align="left">
</p>
<br />
<center>
</center>
<br />
<br />
<p align="left">
<b>GeForce GTX 780Ti</b> <br />
- GPU: GeForce GTX 780Ti (GK110) <br />
- Core Base Clock: 876MHz <br />
- Core Boost Clock: 928MHz <br />
- Memory Size: 3072MB GDDR5 <br />
- Bus Type: PCI Express 3.0 <br />
- Memory Bus: 384-bit <br />
- CUDA Cores: 2880 <br />
- DirectX 11.2: Yes <br />
- DVI Port: DVI-I /DVI-D <br />
- HDCP: Yes <br />
- HDMI: Yes <br />
- Warranty: 2yr
</p>
<p align="left">
</p>
Was [£539.99] Inc. VAT
Only £509.99 inc VAT.
ORDER NOW
Inno3D GeForce GTX 780Ti iChill OC 3072MB GDDR5 PCI-Express Graphics Card (N78T-1DDN-L5HS) @ £547.99 inc VAT
nonl2br
<p align="left">
</p>
<p align="left">
</p>
<p align="left">
</p>
<p align="left">
</p>
<br />
<center>
</center>
<br />
<br />
<p align="left">
- Core Base Clock: TBAMHz <br />
- Core Boost Clock: TBAMHz <br />
- HDCP: Yes <br />
- HDMI: Yes <br />
- Warranty: 3yr
</p>
<p align="left">
</p>
Was [£619.99] Inc. VAT
Only £547.99 inc VAT.
ORDER NOW
MSI GeForce GTX 780Ti Gaming Edition 3072MB GDDR5 PCI-Express Graphics Card @ £509.99 inc VAT
One of the deciding factors in performance is the quality of the components used. That is why MSI only uses MIL-STD-810G certified components for its Gaming cards because only these components have proven to be able to withstand the torturous circumstances of extreme gaming and overclocking.
One With their aluminum core design, Solid CAP's have been a staple in high-end design mainboard designs and provides lower Equivalent Series Resistance (ESR) as well as its over-10-year lifespan. A Hi-c CAP is a very small, but super-efficient capacitor. Besides ensuring enough spacing around a CPU socket to install large coolers, it also allows for 93% energy efficiency. Thanks to Hi-c CAP's MSI mainboards are the most energy efficient in the market. It’s a new generation, form-in-one choke, which doesn’t generate vibration noise under heavy loading & provide 37,5% higher current output comparing with traditional ring chock. It’s very important when GPU is overclocked or under high loading, since it requires even more amount of electricity which can be provided through this component.
Specification:-
- GeForce GTX 780Ti
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
ORDER NOW
Asus GeForce GTX 780 Direct CU II OC 3072MB GDDR5 PCI-Express Graphics Card @ £399.95 inc VAT
The newly arrived ASUS GTX780-DC2OC-3GD5 ships with 28nm GPU and 3GB GDDR5. To fully harness the power of new GPU technology, ASUS GTX780-DC2OC-3GD5 built with ASUS exclusive DirectCU II design featuring a 40% more efficient 10mm copper heat-pipe, 2.2X larger dissipation surface are and unique CoolTech fan that ensures 30% cooler and up to 3X quieter performance than reference. For enhanced overclocked headroom and gaming experience, ASUS redesign GTX780 with DIGI+ VRM offering precise digital delivery for better software overclocking stability. For enhanced overclocked headroom, ASUS GTX780-DC2OC-3GD5 uses 8+2 phase power design in Super Alloy Power technology, compared to 6+2 phase power design in reference card. In addition, GPU Tweak utility helps users modify and tune boost clock speed, power target, temperature target and fan performance via an intuitive interface. This card uses PCI Express 3.0 as the standard interface, doubling the data bandwidth of PCI Express 2.0. The power of ASUS GTX780-DC2OC-3GD5 also supports NVIDIA® Adaptive VSync technology and 3D Vision® surround™. ASUS GTX780-DC2OC-3GD5 provides fantastic gaming experience!
Features:-
- 941MHz Boost Clock
- 30% cooler and 3X quieter performance with ASUS exclusive DirectCU II thermal solution
- ASUS uses 8+2 phase power design in DIGI+ VRM and Super Alloy Power technology for precise digital delivery and enhanced overclocked headroom.
- GPU Tweak utility allows you to tune graphics card performance and check card status via an intuitive interface
Specification:-
- Core Base Clock: 863 MHz
- Core Boost Clock: 941 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£419.99] Inc. VAT
ORDER NOW
Gigabyte GeForce GTX 780 WindForce 3x OC Rev2.0 3072MB GDDR5 PCI-Express Graphics Card (GV-N780OC-3GD) @ £379.99 inc VAT
The new GeForce GTX 780 is all about hyper-realistic gaming and next generation technology. The GeForce GTX 780 features the same record-breaking GK110 GPU used in GeForce GTX TITAN. The massively powerful NVIDIA Kepler ™ based GPU contains 50% more cores than its GTX 680 predecessor AND comes with 3GB of high-speed GDDR5 and NVIDIA GPU Boost 2.0 technology. GeForce GTX 780's 384-bit memory interface provides up to 288.4GB/sec of peak memory bandwidth to the GPU. All this combines to give you over a 40% gaming performance upgrade.
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up MONITORING, GPU CLOCK, MEMORY CLOCK, FAN, GPU VOLTAGE, Memory VOLTAGE, OSD, ONLINE SUPPORT and update driver, BIOS directly.
Keeping the same 450W Cooling capacity using only 2 slots, the New WINDFORCE 3X 450W cooling system is equipped with two 8mm and four 6mm cooper heat-pipes , inclined fans, and GIGABYTE “Triangle Cool” technology. This not only provides an effective heat dissipation capacity but GPU Boost 2.0 technology also enables higher performance due to a lower temperature.
In the Kepler architecture, support up to four displays on a single card. Satisfy your mulit-screen steup, high definition and extreme gaming experience.
Features:-
- Gigantic 3GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- Rev2.00
- WINDFORCE 3X 450W Cooling system
- Black PCB
- Core Base Clock: 954 MHz
- Core Boost Clock: 1006 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power Connectors: 2x8-Pin
- Warranty: 3yr
Was [£399.95] Inc. VAT
Only £379.99 inc VAT.
ORDER NOW
KFA2 GeForce GTX 780 EX OC 3072MB PCI-Express Graphics Card (78XNH5DN8MSU) @ £379.99 inc VAT
The new GeForce GTX 780 EX OC marks an evolution in gaming. Factory overclocked for faster performance right out of the box, produced with a Dual fan cooler with sleek designer shroud and Quad heat pipes with hybrid copper/aluminum fins for maximum cooling efficiency.
Features:-
Specification:-
- Core Base Clock: 967 MHz
- Core Boost Clock: 1019 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
ORDER NOW
KFA2 GeForce GTX 780 HOF 3072MB GDDR5 PCI-Express Graphics Card **ALL WHITE** @ £419.99 inc VAT
Exclusive to Overclockers UK we have the worlds fastest air-cooled GTX 780 - the KFA2 GTX 780 LTD OC or better known to some as the Galaxy Hall of Fame. With many premium and unique features such as Hyper Boost Hardware for maximum clock speeds and cooling. The first GTX 780 to use hybrid heat pipe plus vapor chamber cooling for near silent operation yet very low temperatures. Built and designed using 8+2 phase digital power, premium POSCAP and MLCC capacitors all based on a stunning white looking PCB. If you want the fastest GTX 780 on the market and one which looks different to any other, then look no further!
Features:-
- Hyper Boost hardware overdrive switch supercharges your core clocks
- World’s fastest air-cooled GTX 780 with 1058Mhz boost clock
- 1st GTX 780 with hybrid heat pipe + vapor chamber cooling
- Premium POSCAP and MLCC capacitors
- Winner of multiple overclock world records
- 8+2 phase digital power
- Voltage read points
- Custom white PCB
Specification:-
- Core Base Clock: 1006 MHz
- Core Boost Clock: 1058 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
http://hexus.net/tech/reviews/graphics/60001-kfa2-geforce-gtx-780-hall-of-fame/?page=12
Was [£479.99] Inc. VAT
Only £419.99 inc VAT.
ORDER NOW
Inno3D GeForce GTX 780 iChill HerculeZ X3 Ultra 3072MB GDDR5 PCI-Express Graphics Card (C78V-1SDN-L5HSX) @ £399.95 inc VAT
Features:-
Specification:-
- Core Boost Clock: 1046 MHz
- Memory Clock: 6212 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
- Review: http://hexus.net/tech/reviews/graphics/63393-inno3d-ichill-geforce-gtx-780-herculez-x3-ultra/
ORDER NOW
Inno3D GeForce GTX 780 iChill HerculeZ X3 Ultra DHS Edition 3072MB GDDR5 PCI-Express Graphics Card @ £409.99 inc VAT
This DHS Edition utilises a carefully hand selected and heavily binned GTX 780 GPU, making it ideal for overclocking. Along with the iChill HerculeZ X3 Ultra cooler these cards feature huge overclocking potential.
Features:-
Specification:-
- GPU: GeForce GTX 780 (Specially selecting Binned GPU for maximum OC Potential)
- Core Base Clock: 1046 MHz
- Core Boost Clock: 1085 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Only £409.99 inc VAT.
ORDER NOW
MSI Geforce GTX 780 Gaming Edition OC 3072MB GDDR5 PCI-Express Graphics Card @ £369.95 inc VAT
Features:-
Specification:-
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Only £369.95 inc VAT.
ORDER NOW
MSI GeForce GTX 780 Lightning LE 3072MB GDDR5 PCI-Express Graphics Card @ £399.95 inc VAT
MSI, world renowned graphics card and motherboard manufacturer, has officially announced the release of the GeForce GTX 780 LIGHTNING. This product uses the new exclusive Triple Force Architecture and is equipped with a Triple Level signals LED. The card, from the inside out, represents the next revolution thermal design. The combined power of the Twin BIOS and the card's Enhanced Power Design equip gamers and extreme overclockers with the best graphics card. This superior performance is accompanied by a 20-phase power design that can unlock the limitless potential of the graphics card. Also featuredis the patented GPU Reactor powered back plate design which filters power supply noise and improves overclocking stability. The MSI GeForce GTX 780 LIGHTNING is built using Military Class 4 components that have passed rigorous certification testing in laboratories. With such powerful components, this graphics card is guaranteed to have an impressive service life and excellent overclocking stability. Additionally, the popular 3x3 OC Kits allow for gamers to effectively monitor the status of the graphics card. MSI products are renowned for leading the industry due to the company's innovative R&D, excellent performance, streamlined thermal design, and quality components and software. The MSI GeForce GTX 780 LIGHTNING is once again the most powerful graphics card.
The latest generation of MSI's GeForce GTX 780 LIGHTNING uses Triple Force Architecture. Equipped with a Triple Level Signals LED function, TriFrozr Thermal Design with independent fan control system, and PureDigital PWM control. The Triple Level Signals LED features green, blue, and red lights that represent light, medium and heavy power loads on the device. This ensures that players have complete control over their games or the overclocking process. The innovative TriFrozr Thermal Design with independent fan control far exceeds any traditional or custom cooler's thermal performance and ensures better cooling of the GPU, memory and PWM modules. This iteration of MSI's exclusive design builds upon the PropellerBlade and the Dust Removal Technology of the previous model, alongside seven 8 mm SuperPipes for unrivaled thermal performance. In addition, the PureDigital PWM control technology provides a more stable and accurate voltage signal than traditional designs. The PWM's reaction time is shorter and helps enthusiasts more achieve a higher stability in the most stressful of environments.
Twin BIOS is composed of an original BIOS and overclocking BIOS. The original BIOS allows users to obtain better performancethrough out of the box overclocking, while the overclocking BIOS is specifically designed for extreme LN2 overclocking. By removing restrictions, the capabilities of the graphics card are dramatically increased, which allows users to unlock the card's full potential. The enhanced power supply provides more phases of power than standard models. The GPU has 16 phases, which more than doubles the capabilities of standard designs. The memory of the power supply even has a independent power source, which further supports a foundation for extreme overclocking. Not to mention that MSI's exclusive, patented GPU Reactor filters out extra noise for a stable overclocking experience.
MSI always emphasizes top quality and stability when pursuing the highest in product performance. When developing products, MSI makes satisfying market demands and expectations its primary purpose. The MSI GeForce GTX 780 LIGHTNING introduces the latest Military Class 4 components to the series. The components have gone through rigorous testing in a laboratory to satisfy the Military Standard 810G. Regardless if it is the advantages of the low-temperature, high performance DrMOS 4, the double-sided CopperMOS thermal design, the highly durable and stable tantalum Hi-C Cap cores, the polished surface of the New SFC for added cooling, or the corrosion proof Dark Solid CAP, each aspect of the LIGHTNING ensures the best possible stability.
Designed specifically for overclocking, the 3x3 OC Kits are a must-have for all enthusiasts. The kit allows users to adjust the voltage levels GPU, memory, and PLL through MSI's exclusive Afterburner utility while monitoring GPU, memory, and MOFSET temperatures. V-Check Points also capitalize upon the multi meter measuring of GPU, memory, and PLL voltage levels to give users direct calibration data-a function that guarantees success in the world of extreme overclocking.
Features:
- 16+3+1 (20) Phase Power
- Propeller Blade Technology
- 8 SuperPipes and dense aluminium fins to maximize thermal dissipation
- LN2 Mode
- Triple level signals show the real-time load with different colours
- TriFrozr Thermal Design - Three PWM fans with independent control on the most advanced thermal design.
- Pure digital PWM Control - Digital GPU / Memory / AUX voltages
- Twin BIOS
- Enhanced Power - 16 GPU phases and 3 memory Phases on a custom designed 10 layers PCB for amazing overclocking potential.
- GPU Reactor for improved OC ability providing 300% higher power capacity and reduces power noise (ripple)
- MIL-STD-810G standard certified to ensure the best stability and quality.
- Uses DrMOS 4, CopperMOS, Hi-c CAP, new SFC and Dark Solid CAP.
Specification:-
- Core Base Clock: 889 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- Warranty: 3yr
ORDER NOW
OcUK Geforce GTX 780 3072MB GDDR5 PCI-Express Graphics Card @ £359.99 inc VAT
The next generation GeForce GTX 780 is a high-performance graphics card designed from the ground up to deliver super-fast, smooth and quiet gaming. It features the most advanced technology innovations, engineering and features to deliver spectacular performance in today's most demanding games.
Features:-
Specification:-
- Core Boost Clock: 902 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Was [£379.99] Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
KFA2 GeForce GTX 770 LTD OC 2048MB GDDR5 PCI-Express Graphics Card **WHITE EDITION** (77NPH6DT8KTZ) @ £287.99 inc VAT
The KFA2 GTX 770 LTD OC all white edition is produced with a white PCB, two 8 pin PCI-E power connectors for a maximum TDP, Overclocked. Cooled with custom white three 90mm fans and five heat pipes leading to an aluminum fin array. The result of this is a card which is quieter and cools better, whilst at the same time can also offer great overclocking ability. Then to finish it off this card looks absolutely amazing and is very unique with its all White Design including PCB, Fans and shroud.
Feature-rich and stacked with advanced gaming technologies like NVIDIA® PhysX®, TXAA™, ShadowPlay, and much more. This gives you the performance edge you need to take on next-generation titles like Splinter Cell: Blacklist and many others. It's serious equipment for the serious gamer.
Features:-
- White PCB, White fans, White shroud for that exclusive and unique look
- 2x 8-Pin power connectors for better TDP resulting in better overclocking ability
- Tri-Fan cooling, less noise, better cooling, longer lifespan
- Fastest GTX 770 out the box on the market with 1254MHz Boost Speed!!!
Specification:-
- Core Clock: 1150MHz (GK104)
- Core Boost Clock: 1202MHz
- Memory: 2048MB GDDR5
- Memory Clock: 7010MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2404MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 1x DisplayPort 1.2, 3x HDMI
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- 2x 8-Pin PCI-E Connectors required
- Hexus Review: http://hexus.net/tech/reviews/graphics/57949-kfa2-geforce-gtx-770-ltd-oc/
- Warranty: 2 Years
Only £287.99 inc VAT.
ORDER NOW
Inno3D GeForce GTX 770 iChill HerculeZ X3 Ultra 2048MB GDDR5 PCI-Express Graphics Card (C770-3SDN-E5DSX) @ £269.99 inc VAT
The next generation GeForce GTX 770 is a high-performance graphics card designed from the ground up to deliver super-fast, smooth and quiet gaming. It features the most advanced technology innovations, engineering and features to deliver spectacular performance in today's most demanding games.
Features:-
- Innovative new GeForce architecture, designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA FXAA
- The power of 3-way NVIDIA SLI® technology
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA 3D Vision® Surround multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display) - for the first time ever
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
- New 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
Specification:-
- Core Boost Clock: 1196MHz
- Memory Clock: 7200MHz (Effective)
- Shader Clock: 2170MHz
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 230 watts at stock speed)
- 1x 8-Pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
Only £269.99 inc VAT.
ORDER NOW
Inno3D GeForce GTX 770 iChill HerculeZ X3 Ultra 4096MB GDDR5 PCI-Express Graphics Card (C770-2SDN-M5DSX) @ £299.99 inc VAT
Features:-
Specification:-
- Memory: 4096MB GDDR5
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Was [£319.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
OcUK Geforce GTX 770 2048MB GDDR5 PCI-Express Graphics Card @ £227.99 inc VAT
Features:-
Specification:-
- Core Clock: 1046MHz (GK104)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Only £227.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 760 Phantom 2048MB GDDR5 PCI-Express Graphics Card @ £191.99 inc VAT
nonl2br
<p align="left">
GeForce® GTX 760 is the new weapon of choice for gamers—a powerful graphics card that gives you fast, smooth, quiet performance in all your favorite titles. It’s packed with next-gen technology innovations, engineering, and features that let you crank up the settings and resolutions in graphics-intensive games like Splinter Cell: Blacklist.</p>
<p align="left">
Take hyper-realistic gameplay to a whole new level with NVIDIA GPU Boost 2.0 for max clock speeds, PhysX® and TXAA™ for great graphics, and NVIDIA® SHIELD™ compatibility for incredible portable gaming. Plus, instantly access the latest game-ready drivers automatically—the day a game launches—and optimize settings with one click using GeForce Experience™. Even auto-record all your greatest gaming moments with NVIDIA ShadowPlay.</p>
<p align="left">
This is serious equipment for the serious gamer.</p><br />
<center>
<object width="640" height="360"><param name="movie" value="//www.youtube.com/v/efc3ySUBNsg?version=3&amp;hl=en_GB&amp;rel=0"></param><param name="allowFullScreen" value="false"></param><param name="allowscriptaccess" value="always"></param><embed src="//www.youtube.com/v/efc3ySUBNsg?version=3&amp;hl=en_GB&amp;rel=0" type="application/x-shockwave-flash" width="640" height="360" allowscriptaccess="always" allowfullscreen="false"></embed></object>
</center>
<br />
<br />
<p align="left">
<b>Specification:</b><br />
- Core Clock: 1072MHz (GK104)<br />
- Core Boost Clock: 1137MHz<br />
- Memory: 2048MB GDDR5<br />
- Memory Clock: 6200MHz (Effective)<br />
- Memory Interface: 256-Bit<br />
- Processing Cores: 1152<br />
- Shader Clock: 2144MHz<br />
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)<br />
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport<br />
- SLI Ready (Upto 3-Way SLI Supported)<br />
- HDCP Capable<br />
- DirectX 11 Support<br />
- OpenGL 4.0 Support<br />
- PhysX Enabled<br />
- CUDA Enabled<br />
- 3D Vision Enabled<br />
- NVIDIA Surround Enabled<br />
- Lower power consumption (Maximum consumption 170 watts at stock speed)<br />
- 1x 8-pin & 1x 6-Pin PCI-E Connectors required<br />
- Warranty: 2 Years</p>
Was [£199.99] Inc. VAT
Only £191.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 760 WindForce 3x OC Rev2 2048MB GDDR5 PCI-Express Graphics Card **Black PCB** @ £191.99 inc VAT
nonl2br
<p align="left">
<p align="left">
<p align="left">
<center>
</center>
<br />
<br />
<p align="left">
<b>Features:</><br />
- Ultra Durable VGA Design<br />
- WindForce 3x Cooler - Quieter, Cooler, better fans with Triangle Cool Technology<br />
- GPU Boost 2.0<br />
- Support up to 4 displays at single car and maximum 4k resolutions<br />
- Direct Heat Pipe touch technology (DHT)</p><br />
<p align="left">
- Black PCB Edition (Revision 2.0)<br />
- Core Clock: 1085MHz (GK104)<br />
- Core Boost Clock: 1150MHzv
- Memory Clock: 6008MHz (Effective)<br />
- Shader Clock: 2116MHz<br />
- Warranty: 3 Years</p>
ORDER NOW
OcUK GeForce GTX 760 2048MB GDDR5 PCI-Express Graphics Card @ £175.99 inc VAT
nonl2br
<p align="left">
The OcUK GTX 760 is a powerful, feature-rich card stacked with advanced gaming technologies like NVIDIA® PhysX®, TXAA™, ShadowPlay, and much more. This gives you the performance edge you need to take on next-generation titles like Splinter Cell: Blacklist and many others. It's serious equipment for the serious gamer.</p><br />
<center>
</center>
<br />
<br />
<p align="left">
- Core Clock: 980MHz (GK104)<br />
- Core Boost Clock: 1033MHz<br />
- Shader Clock: 1960MHz<br />
- 1x 6-Pin PCI-E Connectors required<br />
Was [£185.99] Inc. VAT
Only £175.99 inc VAT.
ORDER NOW
Akasa Cobra Power 850W Modular Power Supply PSU @ £71.99 inc VAT
The Akasa Cobra power supply series brings flat, low profile modular cables allowing for easy cable routing and better airflow.
The modular cable design allows use of the cables you need to improve internal airflow and reduce clutter for better cable management. Low-profile, flat cable design also helps to reduce friction in airflow and maximises it throughout your computer's chassis.
With a typical 82% efficiency, Cobra is not only saving you money on your electricity bill and is also reducing heat in your computer to extend its life.
Features:-
Modular cable management enhances airflow
Dynamic single 12V rail for power hungry hardware
Thermally controlled ultra quiet fan
Cobra strip cable is neat and manageable
Spefication:-
- Form factor: ATX 12V 2.3
- Dimensions: 150 x 160 x 86mm (W x L x H )
- Typical efficiency: Over 80%
- Power Factor Correction: Active PFC
- Fan:135 x 135 x 25mm, thermal control
- Motherboard connector: 1 (20+4pin )
- ATX12V connectors: 1 (4+4pin)
- PCIe 6+2pin connectors: 4
- SATA connectors: 6
- Molex 4pin connectors: 3
- FDD 4pin connectors: 1
- AC power input: 240V AC
- Protection: Over Power / Voltage / Current Protection
Was [£79.99] Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
Corsair RM Series RM 750 '80+ Gold' 750W Power Supply (CP-9020055-UK) @ £99.95 inc VAT
Corsair RM Series power supplies are fully modular and optimized for silence and high efficiency. Zero RPM Fan Mode means that the fan doesn’t even spin until the power supply is under heavy load, and the fan is custom-designed for low noise operation even at high loads. 80 PLUS Gold rated efficiency saves you money on your power bill, and the flat black cables are fully modular, so you can enjoy fast, neat builds. And, like all Corsair power supplies, RM Series is built with high-quality components and is guaranteed to deliver clean, stable, continuous power. Connect it to your Corsair Link system and you can even monitor fan speed and +12V current directly from your desktop (additional cable required for 450W-850W units).
Product features:
- Optimized for Silence: The components used to manufacture the RM Series are manufactured specifically for excellent performance and low audible noise.
- 80 PLUS Gold-certified Efficiency: Highly efficient RM Series power supplies produce less heat and have lower operating costs.
- Flat black, Low-Profile Modular Cables: You can use only the cables you need, and leave the rest in the box for fast, easy, and great-looking builds.
- Reliable, Continuous Power Delivery: Corsair uses high-quality internal components, and RM Series power supplies are guaranteed to deliver clean, stable, continuous power.
- Corsair Link Compatible: RM Series power supplies connect to Corsair Link software for real-time monitoring of fan speed and power delivery directly from your desktop. Additional hardware required for 450W-850W units.
- The latest ATX12V v2.4 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2, 2.31 and ATX12V 2.01 systems.
- 4th generation Intel® Core™ processor Ready (Intel Haswell and Z78 motherboards)
- 80PLUS Gold certified, delivering over 92% energy efficiency at real world load conditions.
- The completely modular cable system allows you to use only the cables you need.
- Low-profile, flat cable design reduces air friction and helps maximize airflow through your computer’s chassis.
- High-quality capacitors provide uncompromised performance and reliability.
- A five year warranty and lifetime access to Corsair’s legendary technical support and customer service.
- Active Power Factor Correction (PFC) with PF value of 0.99.
- 135MM NR135L Noise reducing fan. MTBF: 100,000 Hours
- Universal AC input from 100~240V.
- Multi-GPU Ready
- Over-voltage and over-current protection, under-voltage protection, and short circuit protection, over power protection, over temperature protection provide maximum safety to your critical system components.
- Safety and Agency Approvals: FCC, ICES, CE, C TUV US, RCM, TUV, CB, CCC, BSMI, GOST, ROHS, WEEE, ROHS, KC
ORDER NOW
Corsair RM Series RM 850 '80+ Gold' 850W Power Supply (CP-9020056-UK) @ £119.99 inc VAT
Product features:
- Multi-GPU Ready
Was [£129.95] Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Corsair AX1200i Digital ATX '80 Plus Platinum' Modular Power Supply (CP-9020008-UK) @ £239.99 inc VAT
Unlike traditional power supply designs, the Corsair AX1200i uses a Digital Signal Processor (DSP) for tighter voltage regulation and lower elctrical ripple and noise which improves overall system stability and component reliability. Upgrading to digital provides increased efficiency. The AX1200i is certified 80 Plus: Platinium, which results in lower heat generation and a quierter fan profile. The AX1200i is so efficient that the 140mm fan doesn't even spin at low loads for completely noiseless power dellivery. The build int Corsair Link function allows you to know how well your AX1200i is working at any given moment and lets you quickly tweek its performance. Server-inspired diagnostic tools monitor real-time efficientcy, power usage, configurable over current protection ppoints and fan profiles. The fully modular cables make it easy to install and the self-test switch lets you quickly determine if the AX1200i is functioning normally before you even attach cable to your motherboard.
- Digital Signal Processor (DSP) for delivering extremely clean, efficient power with real-time adjustments.
- Corsair Link™ Integration for monitoring and adjustment of performance, noise, and OCP settings.
- 80 PLUS® Platinum Efficiency for lower power usage and energy costs.
- Fanless operation at low loads, for outstanding noise reduiction.
- 140mm thermally controlled double-ball bearing fan spins up as needed.
- Fully Modular low profile cables for easy installation and less clutter.
- Engineered to meet maximum power output at a server-grade 50C temperature rating.
- Self-test switch to determine PSU functionality even before installation.
ORDER NOW
Enermax Platimax 1350w '80 Plus Platinum' Modular Power Supply (EPM1350EWT) @ £269.99 inc VAT
Fully utilize transformer’s quad magnetic quadrants energy to provide maximum switching efficiency and outstanding KW output stability.
World’s leading modular cable PSU series with 89-94% efficiency @ 20-100% load. Compliant with 80PLUS® PLATINUM efficiency requirement.
Specification:-
- Type: ATX12V / EPS12V
- Maximum Power: 1350W
- Fans: 1 PFC Active
- Main Connector: 24Pin+12V Rails
- 6PCI-Express Connector 8 x 6+2-Pin
- SATA Power Connector 14
- SLI Ready / CrossFireCrossFire Ready
- Modular: Full Modular
- Efficiency: 89-94% @ 20-100% loadEnergy
- Efficient80 PLUS PLATINUM Certified
- Over Voltage Protection: Yes
- Input Voltage: 110-240VAC (Max. range: 100-264VAC)
- Input Frequency Range50-60Hz (Max. range: 47-63Hz)
- Input Current: 14 - 6.5AOutput+3.3V@24A, +5V@24A, +12V1@20A, +12V2@20A, +12V3@30A, +12V4@30A, +12V5@30A, +12V6@30A, [email protected], +5VSB@3A
- Connectors1 x 24pin & 8pin MB/CPU
- 1 x 8pin & 4pin 12V CPU/RAM
- 4 x (2 x PCI-E 6+2pin)
- 3 x (4 x SATA)
- 2 x (4 x 4pin Molex + FDD)
- 1 x (2 x SATA + 2 x 4pin Molex)
- Warranty: 5yr
ORDER NOW
Enermax Platimax 1000w '80 Plus Platinum' Modular Power Supply (EPM1000EWT) @ £217.99 inc VAT
The Enermax Platimax 1000W is a High-performance power supply topology which uses all magnetic quadrants of the main transformer to achieve maximum efficiency and rock stable output voltage. It features Innovative and patented transmission technology for direct voltage transmission to reduce the wire-resistance and to increase the efficiency.
- 80 Plus Platinum
- Dynamic Hybrid Transformer Topology
- Copper Bridge Array
- Multi Rail Design
- Special OC Edition
- Future ready and flexible
- Full Modular Cable Management
- Fit4Server
- DX 11 Ready
- HeatGuard
- CordGuard
- SafeGuard
- High Quality Japanese Capacitors
- 5 Year Warranty
Was [£229.99] Inc. VAT
Only £217.99 inc VAT.
ORDER NOW
EVGA SuperNova NEX 1500W Digital Classified Modular Power Supply @ £359.99 inc VAT
The EVGA SuperNOVA NEX1500 Classified is the ultimate enthusiast power supply. Designed to support the toughest hardware, the EVGA NEX1500 Classified supports ground-breaking new features like SuperNOVA enthusiast software control, Overclock Mode that increases the maximum power output up to 1650W*, and fully modular, individually sleeved cables.
You can also count on EVGA to provide the utmost reliability and performance, with 100% Japanese capacitors and a durable ball bearing fan. The NEX1500 Classified is designed from start to finish to be the best choice for today's most demanding high-end computers. Get to the next level with the EVGA NEX1500 Classified Power Supply!
Continuous Power: Trust EVGA to label all of our power supplies in Continuous Power, the steady power a PSU can output continuously, rather than the amount delivered at its short-lived peak.
SuperNOVA Software: Exclusive SuperNOVA software allows you to monitor voltage, current drawn on each rail, power used, efficiency, allows you to change the fan profile and even adjust the +12V rail!
Single OR multiple 12V Rails: No longer will you have to toil over the decision of choosing a single or multiple rail PSU; the NEX1500 Classified lets you switch modes as you please.
Fully Modular, Individually Sleeved:EVGA delivers the highest quality cables possible, with individually sleeved cables and a fully modular design for optimal cable management and the best looks. On top of that EVGA supplies a massive 12AWG premium power cable!
- Provides up to 1650W of power
- Provides up to 133Amp on the +12V rail
- SuperNova software allows power monitoring and adjustements
- 100% modular cable design with individually sleeved wires
- Digital Power Design allows for single or multiple rails
- Run multiple power supplies with ease
- Custom 12 Gauge EVGA Power cored
- 80 Plus Gold Certified
- Cables: 1x24pin / 2 x 8pin CPU / 3 x 6pin PCI-E / 16 x 6+2pin PCI-E / 12 x SATA / 8 x Molex / 2 x floppy / 1 x mini USB / 1 x 12 Gauge EVGA Power Cable
ORDER NOW
NZXT Hale Power 90+ 850W '80 Plus Gold' Modular Power Supply @ £129.95 inc VAT
NZXT introduces the 80+ gold certified HALE90 series built from the ground up specifically customized for gamers and enthusiasts and offers incredibly efficient operation that will meet the needs of even the most power hungry enthusiasts.
• 80+ Gold certified: The HALE 90 series from NZXT operates at ultra high efficiency, at 20%, 50% and 100% loads, efficiencies are 87%, 90%, and 87% respectively.
• Single140mm two ball-bearing fan operates with minimal noise even at full load. Maximum decibel levels are 20db for wattages between 550-750W and 30db for 850W and above.
• Strong Single Rail Design: A single +12V rail provides stability and ease of use making the most out of your power supply. Offers stable & clean current delivery under heavy load.
• Modular cable design: Modular cable design allows the user to pick and choose which cables they want to use, optimizing cable management and airflow inside the chassis. Flat cables allow for easier routing and bending inside the computer chassis during wire management.
• Hybrid LLC resonant Topology circuitry allows the HALE series to create highly efficient power supplies ranging from 550W-> 1000W.
• Full range Design from 100V – 250V with Active PFC.
• 100% Japanese Capacitors: High quality components for longer life time and better reliability.
• Latest CPU support for all the latest INTEL and AMD CPUs like Corei7, i5, AMD Phenom II X4, X3.
• Latest GPU support, ideal for latest DX11 GPUs and comes with 8pin and 8(6+2) pin PCI-E connectors.
• Large tower support: The Hale Series of power supplies have extended 8pin CPU connectors for wire management in large cases which have PSUs mounted at the bottom.
• Compliance with ATX 12V v2.2, EPS 12V v2.91, and SSI EPS 12V v2.92 Specifications.
• Environmentally Responsible: Consuming less than 1W during shut off status Complies with the newest EuP ( Energy-using Products) requirements and USA Energy star standards.
• Continuous Power: The HALE 90 series listed wattage is the continuous operating wattage.
• Keeping it safe: The HALE series offers over voltage, current, power, under voltage, and short circuit protection. The power supply will automatically shutdown to prevent any damage to your system or misuse.
• Warranty: 5 Years
Only £129.95 inc VAT.
ORDER NOW
NZXT Hale Power 90+ 1000W '80 Plus Gold' Modular Power Supply @ £149.99 inc VAT
• Warranty: 5 Years
ORDER NOW
Seasonic G series 750w '80 Plus Gold' Modular Power Supply @ £99.95 inc VAT
For the ultimate in low wattage, high quality PSU needs comes the Seasonic G Series PSU with 360 / 450 / 550 / 650 and 750w options these units are perfect for any HTPC or mid range gaming system.
- 80 Plug Gold Certified
- DC to DC Converter Design
- Tight Voltage Regulations (±3%)
- Smart and Silent Fan Control
- High Reliable Aluminum Electrolytic Capacitors
- Conductive Polymer Aluminum Solid Capacitors
- Detachable Modular Cables
- High Current Gold Plated Terminals
- 12cm Ball Bearing Cooling Fan
- Ultra Ventilation (honeycomb structure)
- Mulit GPU Technology Support
- Universale AC Input
- 5 Year Warranty
Was [£109.99] Inc. VAT
ORDER NOW
Silverstone SST-ZM1350 Zeus Power Supply - 1500W Peak @ £239.99 inc VAT
After a four year hiatus, SilverStone’s top of the line power supply series, Zeus, has finally returned. The all new Zeus ZM1350 retains excellent characteristics of its predecessors with continuous output of 1350W (1500W peak) rated for 24/7 operating at 50°C, ±1% regulation for exceptional stability, and careful selection of premium industrial grade components. Other aspects such as efficiency, modular cabling compatible with other SilverStone PSUs, and adjustable switches for multi/single rail, voltage tweak, and fan control are vastly improved to make this the most thought-after power supply for elites among IT professionals, PC power users, and overclockers.
Features:-
- 1350W continuous output and 1500W peak power at 50°C (60? with 1080W continuous)
- Low ripple & noise with strict ±1% voltage regulation
- Patented six / single +12V rails adjustable switch
- User-accessible +3.3V / +5V / +12V rails voltage adjustment pots
- 80 PLUS Silver certification with 80 PLUS Gold level efficiency at 230Vac
- Class-leading +12V rails combined loading up to 105A
- Industrial grade components
- Advanced 100% full cable management
- Long life dual ball bearing 80mm fan with speed control switch
Specification:-
- Model No. SST-ZM1350
- Max. DC Output 1350W (Peak 1500W)
- Color Black (scratch resistant and lead-free paint)
- Cooling System Single long life dual ball bearing 80mm fan
- Noise Level 20dBA-40dBA
- Dimension 150 mm (W) x 86 mm (H) x 230 mm (D)
- Weight 4.5kg
- Certification 80 PLUS Silver
Protection
- Over Current Protection
- Over Power Protection
- Under Voltage Protection
- Short Circuit Protection
- No Load Protection
Connectors
- 1 x 24 / 20-Pin motherboard connector(500mm)
- 1 x 8 / 4-Pin EPS / ATX 12V connector(700mm)
- 1 x 8 / 4-Pin EPS / ATX 12V connector(500mm)
- 6 x 8 / 6-Pin PCIE connector(500mm)
- 2 x 8 / 6-Pin PCIE connector(500mm / 150mm)
- 16 x SATA connector (500mm / 150mm / 150mm / 150mm)
- 6 x 4-Pin Peripheral connector (500mm / 150mm / 150mm)
- 2 x 4-Pin Floppy connector (500mm / 150mm / 150mm / 150mm)
Was [£299.99] Inc. VAT
ORDER NOW
Thermaltake Toughpower XT 1475W '80 Plus Gold' Modular Power Supply @ £359.99 inc VAT
Toughpower XT GOLD features Japanese made electrolytic capacitors & solid state capacitors with low ESR, which greatly improves the durability and offers the highest stability and reliability. Toughpower XT GOLD adopts full bridge & LLC resonance circuit for extremely stable performance & reliability. Besides, built in the interleaved PFC circuit, Toughpower XT GOLD also provides extremely high PF value and high PSU efficiency. When you open the side panel of your chassis every time, you can see the PSU status quickly and easily. S.P.T. Indicator with 3-mode LED (standby / power good signal / temperature) for real-time monitoring over the power supply not only helps users to know the PSU working status, but also prevents the abnormal situation to protect the system.
- Compliance with Intel ATX 12V 2.3 & SSI EPS 12V 2.92 standards.
- 80 PLUS Gold certified – extreme efficiency PSU series with 87-93% efficiency @ 20-100% load to cut down electric cost.
- 24/7 @ 50℃: Guaranteed to deliver 1475W continuous power.
- S.P.T. Indicator: PSU status monitor with 3-mode LED (standby / PG signal / temperature).
- High quality 105°C Japanese capacitors: ensure superb performance and reliability.
- 105°C Solid state capacitors: great stability at higher operating temperatures, frequencies and currents.
- Full Bridge & LLC resonance circuit with DC-DC module for extremely stable performance & reliability
- Interleaved PFC circuit provides extremely high PF value and high PSU efficiency.
- Massive dual +12V rails: robust dual +12V rails design providing up to 55A for 12V1 & 75A for 12V2.
- Heavy-gauge 16 AWG High Current cable at PCI-Express connectors reduce conducted resistance, increasing efficiency and improving power delivery
- Multi-GPU ready: 8 x PCI-E connectors support up to 4-way ATI CrossFireX & Nvidia SLI.
- Auto switching circuitry for universal AC input from 90-264V.
- High reliability: MTBF>120,000 hours.
- Dimensions: 150mm(W)x86mm(H)x200mm(L).
- Heavy-duty protection circuitry of Over Current, Over Power, Over Voltage, Under Voltage, and Short-Circuit protection.
- Safety / EMI Approvals: CE, TUV, FCC, UL, CUL, GOST and BSMI certified.
Specification:-
- Type ATX 12V 2.3 & SSI EPS 12V 2.92
- Max. Output Capacity 1475W
- Peak Output Capacity 1575W
- Color Black
- Dimension (W / H / D) 150mm(W)x86mm(H)x200mm(L)
- PFC (Power Factor Correction) Active PFC
- Power Good Signal 100-500 msec
- Hold Up Time 16msec (minimum) at 70% of full load at 115Vac input
- Input current 115Vac / 16A max.
- Input Frequency Range 47Hz ~ 63Hz
- Input Voltage 115V - 230V
- Operating Temperature 10? to +50?
- Operating Humidity 20% to 90%,non-condensing
- Storage Temperature -20? to +70?
- Storage Humidity 5% to 95%, non-condensing
- Cooling System 14cm dual ball bearing Fan: 1900RPM ± 10%
- Efficiency MEET 80 Plus Gold at 115Vac input.
- MTBF MTBF>120,000 hours.
- Safety Approval CE, TUV, FCC, UL, CUL, GOST and BSMI certified.
- PCI-E Connector 6+2PIN PCI-E Connector x 6
- 8PIN PCI-E Connector x 2
- Full Specification: http://www.thermaltake.com/products-model_Specification.aspx?id=C_00001812
ORDER NOW
Thermaltake Toughpower XT 1375W '80 Plus Gold' Modular Power Supply @ £269.99 inc VAT
Toughpower XT GOLD features 105?/221? Japanese made electrolytic capacitors & solid state capacitors with low ESR, which greatly improves the durability and offers the highest stability and reliability.
When you open the side panel of your chassis or look through the side window, you can see the PSU status quickly and easily. S.P.T indicator with 3-mode LED (standby / power good signal / temperature) for real-time monitoring over the power supply.
Features:-
- 24/7 @ 50?: Guaranteed to deliver 1375W continuous power even in the worst chassis conditions up to 50? internal chassis temperature.
- S.P.T. Indicator: PSU status monitor with 3-mode LED (standby / PG signal / temperature) will let you know if there's a problem before it becomes a bigger problem or even ceases function.
- Smart Fan Control system optimize the thermal performance and minimize audible noise.
- High current massive +12V rails : robust dual +12V rails design providing up to 50A for 12V1 & 70A for 12V2. This ensures there is plenty of power on demand and ready for any need.
- Heavy-gauge 16 AWG High Current cable at PCI-Express connectors reduce conducted resistance, increasing efficiency and improving power delivery ensuring your high performance graphics cards get the power they need when they need it!
- Multi-GPU ready: 8 x PCI-E connectors support up to 4-way ATI CrossFireX™ & Nvidia SLI™.
- Heavy-duty protection circuitry of Over Current, Over Power, Over Voltage, Under Voltage, and Short-Circuit protection. Helps protect your components should a problem arise.
Specification:-
- Max. Output Capacity 1375W
- Peak Output Capacity 1475W
- Color Black
- Dimension (H x W x D) 150mm(W)x86mm(H)x200mm(L)
- Input current 115Vac / 15A max.
- Input Frequency Range 47Hz - 63Hz
- Input Voltage 100V - 240V
Full Specification: http://www.thermaltake.com/products-model.aspx?id=C_00001811
ORDER NOW
Thermaltake Toughpower XT 1275W ' 80 Plus GOLD' Modular Power Supply @ £199.99 inc VAT
Toughpower XT GOLD features 105?/221? Japanese made electrolytic capacitors & solid state capacitors with low ESR, which greatly improves the durability and offers the highest stability and reliability. Toughpower XT GOLD adopts full bridge & LLC resonance circuit for extremely stable performance & reliability. Besides, built in the interleaved PFC circuit, Toughpower XT GOLD also provides extremely high PF value and high PSU efficiency. When you open the side panel of your chassis or look through the side window, you can see the PSU status quickly and easily. S.P.T indicator with 3-mode LED (standby / power good signal / temperature) for real-time monitoring over the power supply. It helps the user to know the PSU working status, detect abnormal situations and protect your system.
Cable management design improves internal airflow and reduce clutter by allowing removal of unneeded cable sets instead of hiding them.
- 80 PLUS GOLD certified – extreme efficiency PSU series with 89-94% efficiency @ 20-100% load to cut down electric cost.
- 24/7 @ 50℃: Guaranteed to deliver 1275W continuous power even in the worst chassis conditions up to 50℃ internal chassis temperature.
- High current massive +12V rails: robust dual +12V rails design providing up to 45A for 12V1 & 65A for 12V2. This ensures there is plenty of power on demand and ready for any need.
Was [£239.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
So whether your a gamer or your building a mining farm, now is the time to get buying, some great deals on graphics and power supplies. DO NOT MISS OUT!
Hmmm, I wonder if it is a worthwhile upgrade if I get a 270X 4Gb to replace my 6950 2Gb with unlocked shaders?
Gaming at 2560x1440
Hi there
I nearly forgot these pair of gems and I think were the only company in the UK with stock:-
Seasonic X-Series 1250w '80 Plus Gold' Modular Power Supply @ £215.99 inc VAT
Common to all X-Series power supplies, the new X-1050 and X-1250 feature the unique integrated DC connector panel with onboard VRM (Voltage Regulator Module) that enables not only near perfect D-to-D conversion with reduction of current loss / impedance and increase of efficiency but also a fully modular DC cabling that enables maximum flexibility of integration and forward compatibility.
An industry first, advanced 3 phased (Fanless, Silent and Cooling Mode) thermal control balances between silence and cooling. In addition, for X-1050 & 1250 a selector switch is provided to allow you to select between the Seasonic S2FC control, without fanless mode or the S3FC fan control, with fanless mode.
The world-renowned Sanyo Denki Ball bearing fans are made of the highest quality components to ensure maximum quality and performance. The use of spoon shaped high-density plastic fan blades with smoothed leading edges, strict tolerance ball bearings and precision copper axel are just some features to ensure ultra-low noise performance and quality. In addition, the fan uses 3 balancing points, instead of the industry standard of 2 points, to ensure perfect balance and rotation. The Sanyo Denki fan is a perfect match to the class leading Sea Sonic Hybrid Silent Fan control for the absolute top performance of the industry.
- 80PLUS® Gold Certified Super High Efficiency
- Full Modular Cabling Design
- Patented DC Connector Module with Integrated VRM [Voltage Regulator Module]
- Seasonic Hybrid Silent Fan Control
- Sanyo Denki San Ace Silent Fan
- Highly Reliable Japanese Brand Capacitors
- Tight Voltage Regulation [±3%]
- Active Power Factor Correction [99% PF Typical]
- High +12V Output
- Dual Sided PCB Layout
- Ultra Ventilation [Honeycomb Structure]
- Multi-GPU Technologies Supported
- All-in-One DC Cabling Design
- Easy Swap Connector
- Universal AC Input [Full Range]
- 5 Years Warranty
Only £215.99 inc VAT.
ORDER NOW
Seasonic X-Series 1050w '80 Plus Gold' Modular Power Supply @ £169.99 inc VAT
- High +12V Output
- 5 Years Warranty
Only £169.99 inc VAT.
ORDER NOW
Truly epic power supplies from Seasonic, like brands such as Superflower, engineered to perfection and superbly reliable. :)
So tempted to start my pc again with a big seasonic or that white nzxt pus and white nzxt case to match. Need a 290X with proper cooling to match also!
The NZXT PSU's are very nice, they typically use FSP or Superflower as OEM, so good quality. :)
Love the seasonics but having now tried superflower not sure they are still my no 1. Seasonic need to get some illumination going on as its so cool!
