Nice headphones, what Gibson is that?
And are you going to put down a rug to keep the reverb down?
Have you abandoned the in-wall speaker idea?
Ah ok, I saw the speakers change from the little bookshelf (Denons?) to the floor standers and thought they were new.
I'm surprised they aren't enclosed in any way - I appreciate that you gain an advantage from being able to use the volume of the wall as a cabinet but it must make it really hard to make them sound the same if the walls you're putting them in are a bit different.
I'd also be concerned that they would fill up with crap quite easily.
They look good, is there a cover of sorts so they can blend into the wall?
