War Thunder - Free PS4 WW2 Fighter Jet Game - Tips, Tricks, etc
http://forum.warthunder.com/index.php?/topic/102409-war-thunder-update-137/
video in link
The Long expected Update - 1.37 - will bring several significant changes to the game, such as:
A completely different progression system. Learn more from our ‘Developers’ Diaries’.
Many of new planes have been added, such as the Soviet fighters the I-185 and the La-9, the American P-400 (an export variant of the P-39 Airacobra for the RAF). The German Bf 109 F-1 and Bf 109 F-2, The Hs. 129B-3 attacker with an incredible 75 mm cannon, the series of Japanese Ki-84 fighters and others.
New “Custom Battles” mode to test new planes and master your flight and combat skills.
More than 70 aircraft have their Flight and Damage models tuned to fully meet the historically accurate data. Please refer to our forums for the full list and current flight models state report.
New maps and missions added for different modes.
Full list of changes:
New aircraft
Germany:
- Bf.109F-1
- Bf.109F-2
- Fw.190A-8
- Fw.190D-9
- Hs.129B-3
USSR:
- Yak-9U
- Yak-9UT
- MiG-3-15(B) K
- I-185 (М-82)
- Lа-9
- Fw.190D-9 (premium)
- TB-3 (special)
USA:
- P-400
- F9F-2
- XF5F Skyrocket (special)
UK:
- Tempest Mk.V (Vickers P)
- Tempest Mk.II
Japan:
- A6M3 mod22 Ko
- A6M5 otsu
- Ki-84 hei
- Ki-84 otsu
- Ki-84 ko
- B7A2
- A7He1 (premium)
Game play:
- A New player’s progression system, see details in Developers’ Diaries. ;
- Bots now do not now fly biplanes only - they use aircraft of different types and ranks;
- The “Marker” system has been changed. If an enemy has a higher altitude than you, it will be harder for him to define the type of your aircraft against the ground (distance to recognize aircraft type has been reduced by 20% when the plane is against the ground)
- Adjusted the way modifications influence on flight characteristics is calculated
- Short-term connection losses do not cause permanent disconnection any more
- B-17E bottom turret's shooting angle adjusted
- Gunners now have increased spread which depends on turret turn rate (no more than 0.3 degrees)
- Correct allocation of bots in JiP (“join in progress”). Previously, one of the teams could not have any bots
- Fixed aiming when controlling turret gunners
- Improved physics of AI bots (AI physics is now closer to the actual)
- Improved controls for Simplified mode for several planes
- Fixed matchmaking bug when a player was counted as several players to balance the fight
- The amount of bombs needed to destroy the enemy base in all game modes increased in high level battles (solving the problem of bombers 'rushing' the base). Rewards for destroying the base increased correspondingly
- XP-50 moved from rank II to rank III, XP-55 moved from rank III to rank II
- Eject from the plane on carriers is fixed (now you can return to your plane without losing the aircraft)
- Fire angles of the turrets that were able to rotate 360 degrees are fixed
Interface:
- In the player profile the level and military rank(Prestige) are displayed. Military Ranks(Prestige) are awarded for reaching certain levels.
- Aircraft and battle settings in “Custom battles” can be changed by the host without exiting the game room and closing the session
- Modification window interface changed, research tree interface changed
- Colours adjusted in the research and crew menus
- Added a possibility to purchase all modifications available after a battle with a single click
- PvE missions debriefing fixed
- Debriefing screen stays even after lost connection with the battle server
- Blacklisted user is now muted in voice commands
- Squad interface bug fixed
- Torpedo sight interface is fixed
- Fixed achievements on take-offs and landings
- RP report in the log now shows RP gained for new aircraft, not modifications
- Several improvements to radio commands
- Devoiced users have their radio commands blocked
- Reduced limits of anti-flood filters for radio commands to avoid radio-commands spamming
- Many fixes to the Event interface
- Players that are not yet connected to the battle are now shown in the scoreboard menu
- “Anarchist” title and achievements based on bombs and rockets are fixed
Graphics:
- Graphics for all maps and locations have been reworked.
- Models and cockpits for certain aircraft have been fixed.
- Visual models for the I-16 type 18 and the I-16 type 28 have been fixed.
- Pilot indicator is added for air brake status, the modifications are mounted on the wings Ju.87 B-2, R-2, D-3 and D-5;
- Changed the reflex sight on D.520, N1K2-J, N1K2-Ja;
- Fixed and fully functional counters for ammunition status on the Bf.109 series (Exception is a numerical counter in the Emil, others have visual indicators);
- Added ammunition counter bar indicators on all aircraft series Fw.190, the A-5/U2 , F- 8, as well as on the A- 5 ( shows ammo MG-FF) and A-8 (not functioning due to the absence of pendant arms);
- Added the ability to put on the ground adjusted trim tabs. (Which cannot be adjusted in flight);
- Improved rendering of fire, explosions and smoke ;
- Added a new effect for burning fuel tanks . Each fuel tank has its own fire effect
- Grass rendering optimized
- Optimized rendering for clouds and landscape
- Visual bugs are fixed for P-40, Yak-3, I-185 M-82, MiG-9, FW-190А-8, Ki-84
Sound:
- Reduced volume of sound effects for aerobatic smoke;
- Optimization of sound interface parameters;
- Fixed sound settings of multiple bullet hits on the player aircraft;
- Added new sound effects for the gun BK-7, 5 inside and outside the cockpit;
- Added new sound effects for the gun Vickers Class S inside and outside the cockpit.
Changes in DM:
- Fixed the damage model for the XP- 55 ;
- Wellington ( all models) - Fixed the damage model of the fuselage ;
- Fixed the damage model for the D.520 and D.521;
- Fixed the damage model for wings of IL-2 , IL -2M , IL- 10
- Pilots’ and gunners’ damage area is reduced for all planes. The shape of damage area is now close to average man’s shape. Chance to knock the pilot or gunner out is reduced: from the side by 40-50%, from the front and from the rear by 10-15%, from above and from below - by 20-30%.
Changes in FM:
Flight models partially adjusted or completely corrected according to datasheets/passports :
A6M3, A6M3 mod 22, A6M3 mod 22ko, A-20G-30, A-26C, A-26C-45-DT, B-25J-1, B-25J-20, B-25J-30, Havock Mk I, P-47D-25, P-47D-28, I-16 type 18, I-16 type 28, P-400, P-39Q-15, Typhoon Mk-Ia, Typhoon Mk. Ib, Typhoon Mk. Ib/L,I-15 bis, I-15 WR, I-15 М-22, I-15 K, I-185 М-82, Yak-3, Yak-3P, Yak-9U, Yak-9UT, Yak-9P, P-26A-33, P-26A-34 M2, P-26B-35, SBD-3, Tempest Mk. II, Tempest Mk. V, Tempest Mk V (Vickers P), P-36A, P-36A Rasmussen’s, P-36C, P-36G, B7A2, FW-190D-9, FW-190D-12, FW-190D-13, Spitfire L.F. IX,SB-2 M-100,I-153 М62, I-153 P, Ki-84 ko, Ki-84 otsu, Ki-84 hei, Swordfish Mk.I, B-17E, B-17E/L, B-17G, B-24D, He 51 A-1, He 51 B-1, He 51 C-1, Bf.109 E-1, Bf.109 E-3, Bf.109 F-1, Bf.109 F-2, Bf.109 F-4, Bf.109 F-4/trop, Bf.109 G-10, Bf.109 K-4, Lа-9, Fw.190A-5, Fw.190A-8, Beaufighter Mk VIc, PBY-5, PBY-5a, Hs.129 B-2, Hs.129 B-3, Ar-2, B-25J-20, Bf109 G-2, He 51 B-1, Hs129 B-2, Hs129 B-3, I-16 type 18, I-16 type 28, I-185 (М-82), Ki-10 I, Ki-10, LaGG-3-23, P-39N-0, P-39Q-15, SB 2М-100, SB 2М-103, SB 2М-103U MV-3, SB 2М-105
Corrected and updated :
- Hs.129B- 2 (B- 3) : added startup of the engines smoke effect, jet wash moment (compression model) for counter-rotating propellers removed ; FM configured according to datasheet/passport data ;
- For many planes adjusted effect of engine overheating . Permanent engine overheating leads to the gradual destruction of aircraft propulsion units, until the engine stops. Engine damage is indicated in the interface damage indicator (paper doll) - pink, red and black motor;Implemented in simulation and realistic mode
- Many aircraft corrected fuel consumption according to datasheet/passport data and modes of operation of the engine;
- For all aircraft included the effect of heaviness of rudder at high speeds (the higher the speed of the aircraft, the higher the pressure of the oncoming air, the more resistance is needed to overcome). Implemented in simulation and realistic mode
- Fixed performance of the flaps for all of the SB planes
- Trimming of the I-16 improved slightly
- Bf 109 K-4, Bf 109 G-6, Bf 109 G-2, Bf 109 G-10 – fixed issue with heavy rudders
- Minor fixes to Ar-2
Weapons and modifications:
United States:
- Added M10 for guiding planes P-39N- 0 , P-39Q- 5 , P-51D- 5 , P-51D- 20 NA, P-51D- 30 , P-47D- 28 , A-20G- 30 ;
- Added HVAR missiles for the F- 86 Sabre ( all versions) ;
- Fixed bomb load for internal bomb bay B-17E (6x1000 pounds instead 8x1000 pounds );
- Fixed bomb load for internal bomb bay B-17G (4x1000 pounds instead 8x1000 pounds );
- Expanded bombing armament on P-63A- 10;
- Fixed calculation of the weight of bombs for U.S. ;
- Fixed vertical angle aiming for the top turret B-24D;
United Kingdom:
- Tempest Mk.V: added 250 - pound bombs under the wings on pylons ;
- Tempest Mk.II: added 2x250- 2x500 pound and pound bombs under the wings on pylons ;
- Wellington ( all models) : expanded bombing loadouts ;
- Lancaster: expanded bombing loadouts ;
- Beaufighter Mk.X: 12,7 mm M2 Browning machine guns replaced by 7.7 mm machine guns Browning;
- Fixed calculation of the weight of bombs for Britain ;
Germany :
- Added preset 2x936kg torpedoes for He.111H- 6 ;
- Added modification pendant arms BK-3.7 for HS.129B- 2 ;
- Removed 500kg bombs at Bf.109 series G;
- Number SM.79, available for purchase, reduced to 4 . Withdrawn from sale versions: S. 79 1937 and S. 79 1942 ;
- Modification to U4 Me.410 now has , in addition to 50mm BK 5 gun , two 20mm MG 151 cannon ;
- Ammunition BK 5 increased by 1 shell - a shell being charged in the breech ;
- Ammunition Ju.87G- 1 increased from 6 to 12 shells per barrel ;
- Added 20mm motor gun for Bf.109G- 6. Standing motor 30mm gun is now available as a retrofit ;
- Added BK 7,5 gun caliber 75 mm (for gunship Hs.129B- 3);
- Added 13 mm machine gun instead of 7.92- mm machine gun on Me.410B-1/U2.
- Ammunition guns MG-FF Aircraft Fw. 190A-5/U2 changed from 60- ​​to 90 shells per barrel ;
- Added 15 mm MG 151 cannon version ( for fighters Bf.109F- 2);
USSR :
- New Yak- 9UT got 37mm and 45mm hydraulic gun ;
- I -185 ( M-82 ) got rockets and bombs .
- La-5 - removed modification " Rear Armour plate ";
- Fixed ammunition for machine guns ShKAS the Il -10 (750 on the breech );
- Number of SB-2 , available for purchase, reduced to 4 . Withdrawn from sale versions: SB-2M -103 MB- 3, SB-2M - 103U;
- Number of Yer-2, available for purchase, reduced to 4. Withdrawn from sale versions: Yer-2 M-105 TAT and Yer-2 M- 105R TAT.
Japan:
- All planes of the line A6M "Zero" have the opportunity to bear 2x60kg bombs under the wings ;
- Ruler Ki- 84 has the ability to b under the wings 2x50 or 2x250kg bombs ;
- Ki- 43 -2 has the ability to bear 2x50, 2x100 or 2x250kg under the wings ;
- Ki- 61 -lb and Ki- 61 -lc can now bear 2x50, 2x100 or 2x250kg under the wings ;
- N1K2-J - has the ability to bear under the wings 2x250 kg bomb load ;
- Fixed calculation of the weight of bombs for Japan;
- Ammunition for guns Ho- 5 aircraft Ki- 96 and Ki- 102 increased from 200 to 400 shells;
- H6K4 - removed army bomb type 92;
Common:
Striking effect of bombs 50 - 250kg and rockets of all calibers changed to realistic values ​​given in terms of effect on armoured targets :
Rockets caliber 82-114 mm ( RS82 , M8) may destroy medium tanks only with direct hit , heavy tanks are not affected ;
Rockets caliber 127mm - 152mm ( RS-132 , HVAR, RP- 3) destroy medium tanks within 1.5-2m , heavy - with a direct hit ;
100 lbs bombs (50kg) - perhaps can destroy medium tanks within 2 - 3m, heavy - with only a direct hit ;
250 lbs bombs. (100kg) - possibly destroy medium tanks within 4-6m, heavy - within 2-4m ;
500 lbs. bombs (250kg) - possibly destroy medium tanks within 6-8m, heavy tanks - within 4-6m .
Torpedoes performance changed according to their characteristics:
Torpedo Mk.XII - maximum drop height of 40 m
F200- 450 torpedoes and F5W (licensed copy of Italian with the same performance characteristics) - the maximum drop height - 120m.
Torpedo 45 - 36AN obr.1939 year - the maximum drop height of 45m.
Torpedo Mk.13 - early sample (without box stabilizer) - maximum drop height - 30 m;
Torpedo Mk.13 - late sample (box- stabilizer) - maximum drop height - 250 m
Torpedo Type 91 mod.2 and mod.3 - maximum drop height - 300m.
- Fixed ricochet of bombs hitting water surface
- MG-131 AP-I ammo added;
- MG-131 stealth ammo added;
- Fire rate for Ho-5 20mm cannon has been increased from 600 to 800 shots per minute, one-second burst mass increased accordingly in the data;
- Piercing and damage fixed for German 15mm AP shell.
Mission and maps:
New maps :
[ Operation ] The defense of Stalingrad
[ Operation ] Saipan
[ Ground Strike] Ironridge
[ Ground Strike ] Albion ( for low levels )
[ Ground Strike ] Sandy Beach
[ Domination ] Sicily
- All Ground Strike missions for the arcade have zones for bombing. Destruction of each zone takes 10% victory points off the opposing team.
- Missions [ Operation ] Kuban , [ Operation ] Ruhr, [ Operation ] Ardennes, [ Operation ] Berlin , a number of changes aimed at increasing the role of bombers and attackers. In particular:
- Reducing the amount of land held units, affecting the victory points. These are “ heavy class” units , which can only be destroyed by bombs, missiles and large-caliber guns;
- Added zones for bombing. Destruction of each zone takes 10% victory points off the opposing team;
- Completing mission tasks takes 10% victory points off the opposing team;
- Adjustment of ground vehicle movement to improve the balance and greater dispersal techniques on the map;
- Bombers and attack aircraft in the air mission start being closer to enemy ground units, so they will be able to at least have one effective attack
- Airfield on Wake island has been fixed
Separate missions:
- Added Korean theater, which includes three new missions: “Storm Warning ", “Hunting Blind “and "Dangerous Intelligence."
- In the mission of the Pacific theater of battle added: “The Battle of Saipan," “Battle of Guam” and "The Battle of Iwo Jima "
Miscellaneous:
- Numerous fixed and improvements of client’s stability
- Fixed crashes and freezes in client
- Mission editor fixed (choosing weapons and decals now available)
- Fixed crash when reconnecting the server in the hangar
- Fixed login window bug (in some cases player could not enter the game)
- Authorization issue is fixed
Ive kind of stopped playing this, got annoyed that it was sticking me in Tier 3 game modes when im still flying about in the gladiator only unlocked the hurricane 2?
Seems to have been fixed for me that thing. I'm back into tier 1 games on Russia despite having researched planes in tier 2 (haven't bought them yet though).
I think they may have changed it now. I think you go into the tier depending on what planes you have chosen for your crews. So if you are in tier 4 and you choose all tier 2 planes you go into tier 2 matches.
Anyway I hope that's what they have done.
Just had it freeze on me even with the postfx reset?
Apparently caused by free looking, which is what I was doin when it froze
Please excuse me It has been a long day! How exactly do i do that? I just unlocked USA and can flick between USA & GB using L1 and R1 but can't select any other countries.
Oh and i sent a request to join the OCUK squadron.
What's your psn?
Sent a request to join the squadron, gets a little boring with randomers. PSN: Thundery0308
You need to add everyone in op if you want to play together.
Will add you to the list next time I'm near the PC
seem to be getting more rp for mods, but still next to nothing for plane research, also noticed i have dropped back into tier 3 from tier 4
You will only be put in the tier your highest rank plane that your currently using is in.
Basically rp on mods carries over to the next mod now.
They have increased rp for everything though.
So if you are good at the game it's now easier to unlock plane mods as the points carry over, but unlocking planes has become harder for everyone.
No crashes since I reinstalled and haven't touched the touch pad
OMG
Another update 3871 MB people.
Could be the big one we are waiting for or the one which fixes the crashing.
Turn your consoles on remotely if possible by vita or whatever.
Can the PlayStation app turn them on remotely?
FFS with my rural internet this is really p***ing me off, I just want to play the damn game
It's just a bug fix. Stops some of the crashing apparently some of them are still in this version linked with attacking ground targets.
http://forum.warthunder.com/index.p...ying-ground-targets-with-machine-gunscannons/
The game is free and they have rolled out updates and fixes pretty fast.
I don't think we can really complain about improvements to the game.
Switch your console on then put it into standby mode and do something else. Or if your at work and someone else is in the house ask them to do it for you.
I'm glad they have patched the crashing tbh. I'm in the same boat as you used to have 120MB now on about 10MB.
