Career mode won't help you much when you get into FUT! It plays completely differently mainly. You'd be better off just getting stuck into online seasons and then FUT if you wanted an introduction.
Those aren't custom, they are automatically assigned to the dpad. Contain you hold R1+Circle I think or X or RB+B or A on xbox.
If you start UT I'd be willing to give you a small amount of coins to get you started.
A decent non rare side can be had for under 10k.
Playstation only though.
I wish people did R1 + X while on high pressure / team pressing. Most of the time people just use X (contain) and it leaves no space on the pitch. R1 + X is press and contain so uses two defenders. It's suicidal if done at the wrong time. Leaves an easy through ball in behind.
Leave your PSN ID here or trust me it and I'll add you.
Yep it's easy to play against most of the time but when used with certain custom tactics it can be very difficult to pass the ball around effectively.
Just done my first forfeit. Talk about ****ing freeze frame.
I think I'm starting to get slightly better at this. Of a night I'll play about 4 games, normally draw 2, win 1, lose 1 (on average). It used to be lose 3, win/draw 1 so it's a start. Haha.
Definitely need some faster left/right backs, if I make a mistake the wingers are away.
Anyway, a couple of questions.
How do you guys deal with fitness? At the moment I'm waiting till a number of players get to about 70 then getting squad training, it will normally be my strikers, CAM and wingers that need it, the rest of the squad will be fine. Is this the most efficient way of doing it or is there a better way?
What does the health stat do? Is it just how likely an injury will occur?
LOL
you should stream yourself playing, not interested in the game just you raging constantly so make sure camera is pointed directly at you![]()
Pro Clubs is but 1v1 is peer to peer AFAIK.
My current squad, don't know who to upgrade next, I'd get IF Reus if he wasn't a stupid price, 1.2 mil can get me Ribery with 300k change leftover.
