It was used as a branch manager's company car so not hired to the public.
Ok.
Personally I would just drive it until they wear out then replace with a matched set.
I think it would be Michelin (The spare's a michelin) but nowhere seems to have the Primacy HP
The 508's a great bit of kit. We ran an SW and a Passat estate back-to-back for a year and 18k. By the end of it, the Peugeot looked and felt as new. The Pasat, however, was falling to bits and felt very tired.
[TW]Fox;25807707 said:You actually beleive that? Really? How would the dealer even know this for sure to tell you, all you know for sure is that it was run by Europcar.
Did you actually ask why it had 4 mismatched tyres in the first place. Seems very odd indeed. Sounds to me like possible crash/wheel damage?
I would have walked away personally.
Is the spare a full size one? If so then put that on with the other Michelin and;
Put the best of the rest as a spare and replace the other two.
or
Put the worst of the rest as a spare and wait for the others to
For about the 7th time, all 4 were replaced at the same time.
[TW]Fox;25815135 said:I cannot imagine this is actually the case. For a start why would an FWD car with 8k miles need 4 tyres at once?
It's far more likely that it's been unfortunate enough to suffer punctures at different moments and has been therefore fitted with 1 example of whatever was in stock wherever it ended up after each puncture, thats all. Frankly I'd be more comfortable with that explanation than 'all 4 done at once' anyway.
I once drive a rental car at the speed limiter for so long it smelt like fire. Another was brand new delivery mileage, and by the end of my rental it would only start after a few seconds of cranking and stuttering.
