New Build
9 May 2012
Hi Guys,
What do you think of the below build?
YOUR BASKET
1 x Gigabyte GeForce GTX 760 WindForce 3x OC Rev2 2048MB GDDR5 PCI-Express Graphics Card **Black PCB** £199.99
1 x Asus VN247H 24"Widescreen Super Narrow Bezel LED Monitor - Black £179.99
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - OEM £169.99
1 x Gigabyte Z87X-OC Intel Z87 (Socket 1150) DDR3 ATX Motherboard £158.99
1 x Corsair RM Series RM 750 '80+ Gold' 750W Power Supply (CP-9020055-UK) £119.99
1 x NZXT Phantom Enthusiast USB3.0 Full Tower Case - Orange/Black £104.99
1 x Corsair Hydro H80i High Performance Liquid CPU Cooler £71.99
1 x TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (TLAD38G2133HC11ADC01) £69.95
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02733) £67.99
1 x Crucial M500 120GB SATA 6Gb/s Solid State Hard Drive - (CT120M500SSD1) £65.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £41.99
1 x Pioneer 24x Internal DVR-221LBK DVD Rewriter - OEM £17.99
1 x Zalman ZM-K200M Multimedia/Gaming Keyboard £11.99
1 x Gigabyte M6800 1600DPI Gaming Mouse £8.99
Total : £1,308.50 (includes shipping : £14.75).
I was inspired by http://www.overclockers.co.uk/showproduct.php?prodid=FS-368-OE&groupid=43&catid=2475 and really like the orange and black theme - but that is way out of my budget!
I'm looking at a complete build for around £1300. Mostly for gaming and slight photoshop use. Future proofing as much as possible as usual.
On second thoughts not sure if the case I chose is too garish.. hmm
You could probably tweak a few things to get a better gpu. Maybe get the K2 cooler and change the psu for the Seasonic G750. Apart from that it doesn't look too bad.
if i were you id try to squeeze a 280/770 in for the gpu, you could easily save money on the PSU and get get the 650w superflower for £75~
actually, i'll go do a spec, sec
I'd swap out the SSD for a quicker unit..the write speeds on that are a travesty. I'd also swap the 760GTX for a 280X.
Rest looks ok although I've never been a fan of Corsair power supplies as I've had 3 die on me. I prefer Antec, Seasonic or Superflower. In fact you don't need 750w for that lot, a good 550w will do fine. if you wanted a bit of headroom then perhaps a 650w unit.
YOUR BASKET
1 x Sapphire Radeon R9 280X Dual-X OC 3072MB GDDR5 PCI-Express Card £245.99
1 x Antec High Current Gamer M 620W "80+ Bronze" Modular Power Supply £89.99
1 x Toshiba SSD HDTS212EZSTA 9.5mm 128GB Solid State Hard Drive - Retail £65.99
Total : £411.56 (includes shipping : £8.00).
nice big window with orange cable extensions included, and some LED's to light up your interior, better gpu and a more sensible psu choice etc - what i will say is if you're sticking with that case you picked out, the orange highlighted motherboard is pointless as you wont really see it, and you can get something which will suit your purposes perfectly for £50 less which saves you money or frees up more for gpu/better peripherals etc
YOUR BASKET
1 x Gainward GeForce GTX 770 2048MB GDDR5 PCI-Express Graphics Card £249.95
1 x SuperFlower Golden Green HX 650W "80 Plus Gold" Power Supply - Black £73.99
1 x BitFenix Ronin Tower Case - Black £69.95
1 x BitFenix Alchemy Cable Bundle - Orange £28.45
1 x OcUK 20x DVD±RW SATA ReWriter (Black) - OEM £16.99
2 x Akasa "Vegas" White LED strip light - 60cm £8.99 (£17.98)
Total : £1,320.16 (includes shipping : £12.50).
Hi Guys,
Thanks a lot for your help. I've kinda pinched and borrowed from all builds and found a case I like.
YOUR BASKET
1 x Gainward GeForce GTX 780 Phantom 3072MB GDDR5 PCI-Express Graphics Card £359.99
1 x Corsair Carbide 300R Mid Tower Windowed Case - Black (CC-9011017-WW) £78.95
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £59.99
1 x Alpenföhn K2 Mount Doom CPU Cooler £49.99
Total : £1,359.26 (includes shipping : £13.75).
Will I need some more case fans do you think? Going to invest in some orange cabling also - If anyone can suggest how many / what i need that would be great.
If anyone has the monitor in my build too, thoughts would be great. Going to try dig reviews out now. I simply went off price and design originally.
Nice one
Yeah... kinda blew the budget and it doesn't have a keyboard or mouse!
YOUR BASKET
1 x Gigabyte Radeon R9 290 OC WindForce 4096MB GDDR5 PCI-Express Graphics Card (GV-R929OC-4GD) £379.99
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black (CC-9011030-WW) £129.95
1 x Corsair Hydro H110 280mm High Performance Liquid CPU Cooler (CW-9060014-WW) £94.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £79.99
1 x Avexir Core Orange Series 8GB (2x4GB) DDR3 PC3-17200C9 2133MHz Dual Channel Memory Kit (AVD3U21330904G-2CIO) - Orange Light £79.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £59.99
1 x BitFenix Alchemy 24pin ATX extension 30cm - Orange £8.99
1 x BitFenix Alchemy 8pin PCI-E extension 45cm - Orange £6.98
1 x BitFenix Alchemy 6pin PCI-E extension 45cm - Orange £6.49
2 x BitFenix Alchemy SATA 6GB/s braided cable 30cm - Orange £5.99 (£11.98)
1 x BitFenix Alchemy 4-Pin ATX12V Extension 45cm - sleeved orange/black £4.99
1 x BitFenix Alchemy Internal USB Extension 30cm - sleeved orange/black £4.98
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - Orange £4.49
1 x BitFenix Alchemy 2pin I/O extension 30cm - Orange £3.95
Total : £1,543.70 (includes shipping : £12.50).
Yer, starting to get out my price range a lot ha. Good to have the input though thanks.
I really don't like the 540 case design either. Rather have a tower shape. Love the 300r except for the damn vents on side window, spoils the design imo. Never thought i'd be struggling with the case!
Ronin? :)
I've got that exact same dilemma, 300R or Ronin xD I think it would be about £10 anyway to get that window replaced in the 300R with another sheet of perspex. The fan filters on the Ronin are pretty much non existant, not a great point so personally I'm going for the 300R
Let me know if you get the persoex replaced and how easy it is mate.
Just checked out ronin and same situation as you, hate the fact no dust filters.
Yeah haven't ordered the 300R yet, going to ponder it for a day or to.
But yeah, sorry for hijacking thread xD
Either way you'll get a good case. Heaven your second spec looks nice but maybe a higher spec PSU and you could even spend about £15 for a 2TB drive
